I don't have this lappy, however, most newer BIOS settings show an option for a term such as "wireless state" or "Radio status" with options such as on, off, last state. The setting of "last state" should supercede any upgrades or conflicts downloaded after initial settings. Set the BIOS setting to last state and then switch it on. All subsequent boots should have wireless on. To get into BIOS settings, either F2, Delete, Spacebar, or Enter should be pressed during boot sequence. Good luck.
Once you have all the wireless
settings of the router, you are ready to connect the play station or the
x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be
disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will
see your SSID ( wireless network name)==>
select the
security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the
connection .
I HAVE SIMILAR PROBLEM, EXCEPT IT WON'T EVEN TURN ON AT ALL. I JUST GOT DSL CONNECTION AND I CANNOT USE IT WIRELESS - ONLY WITH THE DSL CABLE.
THE WIRELSS LAN WIZARD KEEPS TELLING ME TO TURN BUTTON ON, BUT IT WON'T TURN ON.
IT ALSO SAYS: UNABLE TO DETERMINE WHICH APPLICATION ENABLES WIRELESS LAN. PLEASE ENABLE WIRELESS LAN BEFORE PROCEEDING.
SO IF IT CANNOT DETERMINE THAT, HOW CAN I DETERMINE IT. IT IS OF NO HELP AT ALL!
MARI
