Question about Supersonic Televison & Video
My supersonic dvd won't spin.I have the ac adaptor plug into the power outlet
I just bought a supersonic DVD player and it won't spin.I have the ac adaptor plugged into the power outlet.I have a supersonic 7" portable DVD player model no sc-178dvd
    Master:
  • 444 Answers
Take it back where you got it from, End get your money back ,
Posted on Nov 03, 2012
SOURCE:
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
  • 9 Answers
SOURCE: Durabrand Portable DVD player (Dura-7) AC Adapter
after losing the adapter to my portable dvd player i went to the localwalmart and in the electronics section they had all kinds of ac adapters. a generic one with the same volt rating as your old one should do the trick.
Posted on Apr 11, 2009
  • 303 Answers
SOURCE: Need AC Adapter #PA009UG01
click on hyperlink:
buy replacement ac power charger adapter Audiovox pvs33116
Posted on Jun 01, 2009
SOURCE: Zenith DVP615 Portable DVD AC Adaptor DPAC1
I own this dvd player and the AC adapter broke. Instead of paying for a new cord (if one is even available) we decided to order an AC to DC converter from Amazon so we can use the car cord for the dvd player in the house. We also own an extra long life battery for the machine (from Battery Geek) and use that so we rarely need the ac adapter.
http://www.amazon.com/Power-Line-0900-56-12-Volt-Enhanced/dp/B000QFIS12/ref=sr_1_1?ie=UTF8&s=hi&qid=1256615928&sr=8-1
Posted on Oct 27, 2009
The unit will not power up, it is plugged in to a live outlet. Is there a fuse or a reset?
FAQ: Blu-Ray, DVD and DVR / DVD Recorder ... - Toshiba
https://support.toshiba.com/support/viewContentDetail?contentId...
ToshibaApr 9, 2013 - Blu-Ray Player does not respond to some operating commands during playback; Random lock up of Blu-ray player occurring after the unit is turned off ...Check to make sure that the unit is plugged in securely to the power source (outlet,... Toshiba BD-Live enabled players offer the ability to allow different ...
PDF]BDP - S185 / BX18 - Sonyhttps://docs.sony.com/release/BDPS185_BX18.pdfSony Corporationray Disc/DVD player is harmful to eyes, do not attempt to disassemble ... Install thisunit so that the AC power cord can be ... Connect the equipment into an outlet on a circuit ... type plug has two blades and a third grounding ... Do not turn up the volume while listening to a ... protection systems used in both Blu-ray Disc™ and.[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warrantyhttps://docs.sony.com/.../BDPS1200_BX120_S3200_B...Sony CorporationDVD Player. Operating ... in this Blu-ray Disc/DVD player is harmful to eyes, do not ...Install this unit so that the AC adaptor can be unplugged ... Connect the equipment into an outlet on a ... If the provided plug does not fit into your outlet .... Do not turn upthe volume while listening to a .... BD-Live™, BONUSVIEW™, and the.[PDF]Smart 3D Blu-ray Disc™ / DVD Player with Built-in .
Jan 11, 2016 | Televison & Video
Dvd won't spin
The unit could be new/defective----take it back if new and exchange it---if do that check the new unit before leaving store.
Nov 03, 2012 | Supersonic Televison & Video
I have a supersonic dvd player and it won't spin at all.Model no sc-178 dvd
sorry to say but most likely case is bad motor or turntable issue of some type. unless expensive unit cheaper to buy a new player.
Nov 03, 2012 | Televison & Video
Remote code for supersonic FC-2338
My TV Model FC-02338 is not working. the Ac/Dc Adaptor light stays green until I plug it into tv then it goes on and off. TV flickers
Apr 10, 2012 | Televison & Video
I have a durabrand portable dvd player and I can not get the battery to recharge. I have unplugged it from the DC in jack and the cord from the wall. Reinserted the battery, then inserted the AC adaptor...
If your portable DVD player work with the AC power adapter in the wall outlet.100% the litium battery doesn't take any more holding charges.The litium battery should last u about 2 years with minium usages 2-3 hours a day.But that the DVD player and the litium battery must keep in very well conditon and wheather wise.Not in the heat or cold and the humitnity well shorten the lituim battey life very quickly and also could damages the portable DVD player too dosen't matter how much u used it.Tries webites like Amazon.com,Partstore.com,Ebay.com to buy a new litium battery or a compatible one.
Aug 25, 2011 | Durabrand PDV-709
POLAROID PORTABLE DVD PLAYER CHARGES ON WALL ADAPTOR BUT NOT ON CAR CHARGER
You can buy it at followig link:
http://recoupit.com/Portable-DVD-Players/c177182/
http://cgi.ebay.com/Polaroid-MPA-6930A-AC-Power-Adapter-9-5V-3-33A_W0QQitemZ140312970734QQcmdZViewItemQQptZDVD_Players_Recorders?hash=item20ab4e05ee&_trksid=p4634.c0.m14&_trkparms=|301%3A0|293%3A1|294%3A30
May 08, 2009 | Polaroid PDM-1058 Portable DVD Player
Missing AC adapter
If you look at your DVD player, it will have information such as 5V, 2.2A. This information will help you choose the correct AC adaptor. Head over to The Source, FutureShop, BestBuy, etc and bring the DVD player in.
As for a universal AC adaptor. These range from $15 - $50. Just make sure the one you get has the correct plug and voltage/amp range and polarity for it. The salesperson should be able to help.
Here is a picture of such an adaptor. This is a picture of the back of an electronic device, showing 5V and the polarity. If your player has no information with the AC port, you will need to look for a label on the device with this information.
Dec 01, 2008 | Mintek MDP-5860 Portable DVD Player
PDV880 will not work even when plugged into an outlet
I have the same problem. I ordered a new AC adaptor for this thinking (hoping) that was the problem. Alco Electronics sent me a power cord which doesn't even fit into this.....
Oct 22, 2008 | Venturer 3.6" Portable DVD Player
Supersonic FC2200 TV Power Cord Usage
need a power cord for FC2200 supersonic hdtv. where can i find one
Jun 30, 2008 | Supersonic FC2025 9 in. TV/DVD Combo
Televison & Video Logo
120 people viewed this question
Top Supersonic Televison & Video Experts
Steve Allison
Steve Allison
Demonic-2011
Demonic-2011
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
