Step 1 - Minimize the Moisture
If your watch is exposed to moisture or falls into water, the first thing you want to do is move it to a dry location. Dry off the water on the outside of the watch with a soft rag. The glass on the front can be easily scratched, so be sure to use a soft cloth to wipe clean.
Step 2 - Remove the Cover
Open the cover on the back of the watch very carefully. Often a small flathead screwdriver will help in turning the cover. Pour any water out that remains. Be careful not to touch any of the gears or parts of the watch as the watch may become irreparable.
Step 3 - Air Dry
Lay the watch face down in a warm room to allow it to air dry for at least 24 hours. After replacing the cover, the watch will often return to normal use. However, it is still recommended to have the watch repaired by a professional watch repair shop. They will be able to seal the front and back properly to assure no future leaks. Have them run a pressure test to ensure there are no potential leak areas.
Standard Upkeep
Proper maintenance is imperative, especially on delicate mechanisms like timepieces. Even before your watch fills with moisture or stops working, it is a good idea to maintain it on a regular basis. The inside of a watch is filled with tiny gears and sensitive parts that must be installed perfectly to work properly. Under normal use and regular maintenance, a good watch will work for a lifetime.
It is important to minimize wear and tear when possible. Even though you may not see a crack in the seal, there very well may be one that could ruin your timepiece. Water, especially salt water, can be very damaging to a watch. Find a reputable repair shop to recommend a maintenance schedule for your timepiece.
Read more:
http://www.doityourself.com/stry/how-to-repair-a-watch-with-water-damage#ixzz0x91faKz5
Step 3 - Air Dry
Standard Upkeep
