Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
J Griffin Posted on Nov 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shot gun b b in garbage disposal, can't locate to remove. help.
Gene Haynes
Level 3:
  • Master 5,391 Answers
  • Posted on Nov 03, 2012
Gene Haynes
Master
Level 3:
Answers
5391
Questions
0
Helped
2604887
Points
14124
Use vacuum cleaner down into disposal.
Copy following link for general troubleshoot tips:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 102 Answers
  • Posted on Dec 28, 2012
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
102
Questions
Helped
36712
Points
307
You can also lower a powerful small magnet connected to a string, and it may likely pick up the bb, which is made of steel.
1 Related Answer
Anonymous
  • 12 Answers
  • Posted on Oct 04, 2010
SOURCE: sink garbage disposal not working! when I switch
Do you hear a humming sound when you turn it on? If so, you have a clogged disposal. Check on the bottom for the allen wrench location recessed in the middle of the disposal. Insert the proper size allen wrench and you'll be able to rotate the motor back and forth (sometimes difficult at first) and eventually loosen the clog and free up the motor. If you're able to move the shaft/motor easily in the beginning and it still doesn't work you may have a defective disposal. If you want to check more thoroughly you'll need to check to see if you have power at the disposal when you turn on the switch. Use a electrical tester that you can buy at any home improvement store to see if you have power at the disposal. If so, and the motor turns easily when you use your allen wrench, you have a defective disposal and it needs replacement.
How to remove drain plug from garbage disposal
Good Afternoon Dogman85,
I understand you want to know how to remove the drain plug from your garbage disposal, regarding your Frigidaire dishwasher, model# PLD2850. I suggest contacting the manufacturer of the garbage disposal. They will be able to better assist in removing the drain plug from your garbage disposal. Hope this is helpful.
-Best Regards-
WP
Where is the hex wrench spot on the badger 5 model 5-81 i cant seem to locate where it is
11-2-12
If unit has slot, then it's located on very bottom in center.
Or use a broom.
http://waterheatertimer.org/images/Broom-inside-disposal-350.jpg
Copy following link for steps troubleshooting garbage disposal:
Kitchen sink won't drains only when garbage disposal is on
Remove tubular pipes under sink and clean out disposal.
Copy following links for steps for clogged disposal:
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
I have a Badger 5xp & a double sink. When I turn the disposal on I get a small eruption of water, air and disposed of debris from the other drain.
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
1helpful
Just installed a new garbage disposal now my dishwasher will not drain. after contacting a 1-800 number it was said that a plastic plug must be removed from the garbage disposal in order for the dishwasher...
Just use an object like a screwdriver as a chisel and from the outside of the disposer, insert the screwdriver through the tube that the dishwasher drain hose will be connected to. Use a hammer to give in a firm tap to knock it free. Remove the lose part from inside the disposer, connect the dishwasher drain, and you're set.
Jul 11, 2011 • Dishwashers
Our 1HP Kitchenaid batch disposal does not turn off when the metal plug is removed. It runs for several minutes on it's own.
Replace disposal
Copy following link to repair, troubleshoot and replace disposal:
Add a comment as needed, or repost question with detail
Where is the reset button on the InSinkErator Badger 5, 1/2 HP Garbage Disposal Problems & Solutions?
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Dripping garbage disposal. looks to be dripping from aroud joint where there may b a gasket?
Your leak is due to a break in the plumbers putty at that location. It will have to be taken apart so the old putty can be removed and new plumbers putty can be put in.
Top Buck Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Buck Home Expert? Answer questions, earn points and help others
