Question about Cisco ASA 5520 Firewall
How do i configure pppoe on asa 5520 ver8.4 and remote access vpn?
    Sergeant:
  • 299 Answers
Http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/pppoe.html
Posted on Nov 08, 2012
SOURCE:
  • 7 Answers
SOURCE: asa 5505 firewall problem
PPPoE is not supported when failover is configured on the security appliance, or in multiple context or transparent mode. PPPoE is only supported in single, routed mode, without failover.
http://www.cisco.com/en/US/docs/security/asa/asa81/config/guide/pppoe.html
Posted on Jun 06, 2008
  • 16 Answers
SOURCE: PIX AND ASA Configuration
Voila un link pour un bon simulateur:
http://networksims.com/pix.html
Posted on Feb 12, 2009
  • 101 Answers
SOURCE: how to connect the Cisco ASA 5505 firewall through lan cables?
A conflict in the IP address, resolve it
Posted on Mar 27, 2009
kvgopi
  • 74 Answers
SOURCE: hello all
If you are going for factory reset use the following commands
asa>enable
asa#write erase
asa#reload
Dont save the configuration when it prompts for it.
if you want to restore the configuration from the backup
1. You need to have a TFTP server
2. Locate the config file on your TFTP server
3. TFTP server should be reachable from ASA
then
asa#copy tftp flash
give the tftp server ip address
give the configuration file name (as exactly on the TFTP server)
reload
Posted on May 07, 2009
  • 39 Answers
SOURCE: Problem in installing the asdm image ASA 5520 ver 7.1
1-issue command dir all or show flash
2-delete old file and squeeze it.
3-take out flash card, use card reader to save new asdm file
4.insert back to ASA, change boot system and reload
Posted on Sep 11, 2009
Console to asa 5520
Your are correct, it is a 5520 ASA and thus it requires immediate attention. Console is dependent on the 5520 without a doubt and should you fail to connect them accordingly; the entire process will be in vein. Good luck Captain.
Jan 16, 2013 | Cisco As2511-rj Universal Access Server...
How do I recover firewall password?
You may refer to the steps in the link below:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/trouble.html#wp1049302
I hope this helps!
May 05, 2010 | Cisco ASA 5520 Firewall
Hello all can you please help me on how to restore the configuration of my ASA 5520? thanx
asa>enable
asa#write erase
asa#reload
then
asa#copy tftp flash
reload
Apr 01, 2009 | Cisco ASA 5520 Firewall
ASA LAN failover Problem
The crossover cable should work fine for sure.
Best Regards,
TL
Mar 17, 2009 | Nokia IP 350 Firewall
Nov 20, 2008 | Cisco ASA 5520 Firewall
Cannot Map Drive across VPN
Did you make sure that your user has all security privileges?
Oct 22, 2008 | Computers & Internet
Asa 5505 firewall problem
Jun 06, 2008 | Cisco ASA 5500 Firewall
I had this same issue on my ASA 5520.
1. Copy the config and IOS image to a tftp server.
2. Format flash (disk0)
3. set rommon server, ip addy, and file settings.
4. tftpdnld
5. Once the system has booted to the image copy the asa image file, asdm image file, and config to flash
6. configure asdm image default location and reload
Feb 27, 2008 | Cisco ASA 5520 Firewall
Cisco ASA 5520 Firewall Logo
363 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
