Playback difficulties i'm having issue recording and playing back my recordings on my camera. I recorded some work for a project, but the next day the tape was not working. That day, I recorded and it played back fine, but the next night it was not working again. It's working fine now. I thought maybe I had changed a recording setting, but i haven't touched a thing.
Perhaps these cameras only work before 4 PM?
Not specific enough but I would run a head cleaner thru it for 10 seconds and see if that improves things and always use the same brand of tape to prevent gum issues.
If you are experiencing issues with the playback on your Yashica Samurai Video 8 KX-77 Video Camera Recorder, here are a few troubleshooting steps you can try:
Clean the playback heads: Use a head-cleaning cassette or a cotton swab moistened with isopropyl alcohol to gently clean the playback heads. Dirty heads can cause playback issues and poor picture quality.
Check the tapes: Ensure that the video tapes you are trying to play are in good condition and not damaged. Inspect the tape for any signs of damage or deformation that could affect playback. If the tapes are damaged, you may need to try a different tape or have the damaged tapes repaired.
Adjust the tracking: Use the tracking control on the camera recorder to adjust the playback tracking. The tracking control helps align the playback heads with the tape tracks for optimal playback quality. Experiment with adjusting the tracking to see if it improves the picture quality.
Test with different tapes: If possible, try playing different video tapes to see if the issue persists. This will help determine if the problem is specific to certain tapes or if it is a broader issue with the camera recorder itself.
Seek professional service: If the above steps do not resolve the issue, it may be necessary to seek professional repair or servicing for the camera recorder. Contact a reputable camera repair shop or the manufacturer's customer support for assistance.
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
To record to the DVD, connect the A/V cables from the JVC GR-D347U to the A/V In on the DVD recorder. Since the DVD already plays to the TV, you just have to keep the TV set to that input. Put a blank DVD in the recorder. Set the DVD recorder to record on from the appropriate Line In (input) with the DVD as the target recording media. To make sure that all of the devices are on and receiving the output from the camera and DVD recorder, start playback on the GR-D347U and check that it displays on the TV. Forward the tape in the camera to the point where you want to record to the DVD. Stop playback. Press REC for the DVD recorder and restart your playback. Press stop for both the DVD recorder and then the camera when the desired video segment has been played back.
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
DSC-S500 can record short movie clip with sound and you can playback it on camera and can transfer that movie clip to PC Check below jog-dial mark to set camera to record movie clip.
To playback, set camera to Playback. Need further info, let me know. Thanks.
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Videos with sound is possible or you can record sound memos as well
Recording and Playing Sound Memos You can record and play back sound memos for your photos while you view them on the LCD screen. 1. Turn the Mode dial to playback mode. 2. Press the MENU button. Playback Menu 1 is displayed. 3. Select Sound Memo by using the u d buttons, then press the r button. 4. Press the OK button and then start recording. 5. When you are finished recording, press the OK button. You can play or delete the sound memo or record a new memo. 6. Press the MENU button twice to exit the menu. When you play back a photo that includes a sound memo, the icon appears on the screen. Press the OK button to play the sound. Note: You must have at least one photo saved to record a sound memo.
The SV-AV100 and the SV-AV50 come with an A/V cradle that allows you to connect to external devices for recording and playback. The SV-AS10 and SV-AV25 are not equipped for this operation.
