Televison & Video Logo
Anonymous Posted on Nov 02, 2012
Bush lcd42f1080p100hz remote will not turn tv on
Computer Repairing
Level 3:
  • Master 14,641 Answers
  • Posted on Nov 03, 2012
Computer Repairing
Master
Level 3:
Answers
14641
Questions
0
Helped
719557
Points
53082
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
I need the tv code for a bush BMKDVD40 for a universal remote control
The TV code for the Bush BMKDVD40 for a universal remote control is 0376. You can usually find the code listed in the manual for your universal remote, or you can search for the code online by typing in the model number of your TV.
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room
www.thestudentroom.co.uk > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Is there a Unlock code for bush btvd91216w
This is everything that I have:
Try this general bush unlock:
Press Open tray
Press 2, 8, 1, 2 and Enter to get to the manufacturers settings
Select the required region, by pressing Enter on 9 for multi region
Press Close tray
If that didn't work, try this:
Try this one:
1. Press the Open button on your remote control to open the drive tray
2. Press the 9 button on your remote control
3. Press the 7 button on your remote control
4. Press the 3 button on your remote control
5. Press the 5 button on your remote control
6. Using the on screen menu, highlight the region option
7. Press the Right button on your remote control
8. Using your remote control, select 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
9. Press the Enter button on your remote control
10. Press the Open button on your remote control to close the drive tray
Then there is the following and good luck:
Bush 1000
  1. Open the tray
  2. Insert a disc with desired region code, but do not close the disc tray
  3. Press 0, 1, 2, 3, Play
Bush 1005 / 2004A / DVDAV7
  1. Press the OPEN/CLOSE on the remote
  2. Press 3, 3, 0, 8, 8
  3. Press the button for the desired region or 0 for multi-region
  4. Press OPEN/CLOSE
  5. The on-screen display will now indicate the currently selected region
Bush 2000
  1. Open the disc tray
  2. Insert RC-1 DVD, don't close the disc tray
  3. Press 0, 1, 2, 3
  4. Press PLAY
    To activate RC 2:
  2. Insert RC-2 DVD, don't close the disc tray
  3. Press RETURN and PLAY
Bush 2002 / 2004
  1. Press OPEN
  2. Press 7, ENTER, 7
    A menu should appear (codefree=13)
    Method 2:
  1. Press OPEN
  2. Press 2, 0, 0, 1
Bush 2005 / 2008 / 2009
  1. Turn on the player
  2. Press OPEN/CLOSE
  3. Press ZOOM
  4. Press A/B
  5. Press Up, Left, Down, Right
    A note should be displayed.
  6. Turn it off
  7. Turn it on
Bush 2023 / 2024 / 2523
  1. Press OPEN
  2. Press 2, 8, 1, 2, Enter
  3. Set the country code to 13 and press Close
Bush 2028
    already region free
Bush 2039
  1. Press OPEN
  2. Press PROG
  3. Press ENTER three times
  4. Use UP/DOWN to select region
  5. Press STOP several times to set the region
Bush 2047
  1. Press OPEN, SETUP
  2. Go to "Preferences"
  3. Enter 2, 8, 1, 2
  4. Use UP/DOWN keys to select the region
  5. Press SETUP, OPEN
Bush DVD-102
  1. Press OPEN/CLOSE
  2. Press 2, 0, 0, 1
  3. Press ENTER
  4. Select RC (codefree=13). You can disable MacroVision, too.
  5. Press OPEN/CLOSE
Bush DVD-142TV
  1. Press DVD function on your TV set
  2. Press DVD Setup on the remote
  3. Press 1, 3, 6, 9
  4. Press Left three times
  5. Press RIGHT once
  6. Select VERSION
  7. Change the region code
Bush DVD-143TV
  1. Press DVD/TV, DVD
  2. Open the tray
  3. Press SETUP, Right, Left, Down, Up, Display
  4. Enter 0 (or 1-6 for other RC)
  5. Press Enter
    VCD/SVCD playback
  1. Press SETUP on remote
  2. Press Next, Prev, Next, Prev
    Ver should appear in the top right
  3. Change 3001 to 3000
  4. Change 5001 to 5000
Bush DVDAV11K
  1. Open the tray (be sure to be in stop mode)
  2. Press SETUP, Next, Prev, Next, Prev
  3. Select 255 for region free (use LEFT/RIGHT)
  4. Press SETUP
Bush DVDR3000
  1. The disc tray has to be empty
  2. Press TV/DVDR
  3. Press RETURN, DISPLAY
  4. Enter 8, 8, 8, 0
Bush DVHS1
  1. Press the DVD button on the remote
  2. Press OPEN
  3. Press 0, 5, 2, 0
  4. Press UP, DOWN, LEFT, RIGHT
  5. Change the region (0 = multi-region)
Bush DVRHS02
  1. Push SETUP button on the remote
  2. Select SYSTEM INFO on the menu
  3. Enter 1, 1, 0, 1
  4. It shows the current region code
  5. Push 0 on the remote for region free
Bush 2001 / 2020 / 2026 / 2029 / 2035XI / 2038 / 2042 / 5020 / BTV213DVD / DVR3000 / DVRS01 / PDVD0707 no known hacks
2helpful
How do u program Bush DFTA13HD STB TV buttons
The following is an extract from the Bush DFTA13HD/ DFTA13HDSIL user manual, page 9;
1. Press STUDY key until Red LED remains lit (for about 3 seconds)
2. Point Converter (Bush) remote control to TV remote control directly, keep the distance about 1~3cm
3. Press the "Power" key at TV/s remote control to send signal to Converter remote control. The LED light will flash till steady. Then press "Power" key at Converter remote control. It will record the signal.
4. Now the Power key can turn on/off TV/s power
5. Repeat settings of learning for the other keys
You can repeat Step 3-4 for setting of learning for the other keys at TV remote control, such as VOL /-, CH /-, and F1, F2 are reserved for any other keys you want to set up.
Note:
1. When you have finished setting the learning keys, press the STUDY key to leave the learning status, and the LED light will turn off.
2. The learning function of this remote control may not support all types of TV sets, if you still can not control your TV after you have attempted the above steps, then this remote control may not support your TV or its remote control.
2answers
Bush tv remote code
did you get this sorted? Im having the same problems with my tv and that remote!!
6answers
Sky remote code
codes for bush are
107
031
codes for bush uk are
005
038
140
018
052
143
020
058
152
022
085
169
031
107
172
036
121
175
015
043
141
019
053
144
021
078
156
026
099
171
033
109
173
226
196
hope this helps
10helpful
2answers
Bush tv remote code
i have a bush lcd tv 27 inch an its stuck on stand by i have an urc7740 one forall remote how can i take my tv of stand by with this remote.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
