I've done all puzzles except number 120 and cant find it anywhere, can anyone help.
Http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120
Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
For a picture of the location together with an illustrated solution see
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle120.html
SOURCE: Where is puzzel 120
Hey puzzle number 120 is at the top of the sewer steps near the restaurant and that annoying laughing girl.
Caitlin..x
How do you get into the sewers? I can't see how you get in the sewers? manhole open but went tapping on it nothing happens is there another way in im really stuck!
I can't open the manhole
