Mitsubishi WS-73713 73" Rear Projection Television Logo
Posted on Sep 16, 2017
Scrolling wavey lines or color on screen
When I turn on my ws-73713 with a feed in the component input it will display and scroll wavy lines on the sides. It might stop in a few minutes or it might take all day. When I have a feed in the antenna input it scroll green and purple wavy lines from top and bottom. It also does the same thing when I input to the front of the TV. Can someone help me?
5 Related Answers
Anonymous
  • 1153 Answers
  • Posted on Dec 29, 2007
SOURCE: Mitsubishi WS-65713
Yes Rhonda, first you need to do a self test to show what is going on inside set. You can search threads on test or goto ctechnicians.com. This will put you in the ball park of what is going on.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jun 15, 2008
SOURCE: TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
ginko
Ginko
  • 19396 Answers
  • Posted on Sep 01, 2008
SOURCE: scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Anonymous
  • 11 Answers
  • Posted on Jan 22, 2009
SOURCE: mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
nicknovikov
Nick Novikov
  • 101 Answers
  • Posted on Jan 29, 2010
SOURCE: my WS-55613 mitsubishi projection tv has a rolling
check 9v reg.on the signal board.
Mitsubishi T.V WS-55815 How to go INPUT , NO
Please check with your remote , the input or video 1 will be found on the source or menu selector which can be scrolled with a view on the display.- on screen.
Check this out.
2answers
Wavy colored lines of captioning at all times, can't turn off
Try first unplugging the power cord for fifteen or twenty minutes , see if this can reset and fix the problem.
2helpful
2answers
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
1helpful
Have wavy lines in picture sometimes-could this be a faulty wire?
On the signal board there is 4 surface mount transistors. There is one right by the input board (BA09), i would check the corresponding caps and diodes close to it also. I would replace all of the 4 transistors. If this SMT starts to go you will see wavy lines in your picture than it will go away in 3 min or so and get worse over time until no picture is seen. When it totally fails you will have no inputs what soever but you will have an OSD screen and when you choose DTV you will get a scrolling picture.
When i scroll up and down the page is wavey
If for wavy you mean that it is very jumpy as you scroll, not smooth, then it is a classic sign of the incorrect driver for your video card.
Mitsubishi ws-65313 No Picture
YOU HAVE AT LEAST A DOZEN VIDEO INPUTS ,THE BEST IS THE MONOLINK.WHATEVER WAY YOU HAVE IT HOOKED UP .YOU HAVE TO GO TO THE INPUT MANUAL AND PICK OUT THE ONE YOUR ON .IF YOU DONT WANT TO SPENT 30 BUCKS ON A THE DVI-HMDI MONOLINK CABLE.OR 10.00 ON THE R/G/B TRI CABLE ,FIND ANY COLOR CRAPPY LITTLE SKINNY **** SPEAKER JACK CXABLE AND STICKIT IN THE YELLOW INPUT 1,2 0R 3 THEN GO ON THE INPUT SCREEN AND SCROLL DOWN TO WHATEVER INPUT YOU PUT IT ON.AND OF COURSE HOOK IT TO THE VIDEO OUTPUT ON YOUR BOX SIT BACK AND ENJOY THE 480 P RESOLUTION YOU WIL GET WITH A 50 CENT WIRE.
2answers
Mitsubishi ws-55513
Could be signal board issue,not related to DM.Might be terminal
board problem = less $ and easier to sub than signal PCB.......T.
Scrolling lines
Try using a DVD though the component input (need a 480P out ). If the pix si ok I wouldsuspect the cable box. If the problem is still there I would suspect a video switching IC or a Leaky regulator.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
