Nokia N72 Cellular Phone Logo
suba shidha Posted on Jan 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't receive anything via bluetooth
When i receive pictures from other mobile via bluetooth it ask passcode to me, but i didn't set any passcode. And when i receive MP3 or video clips, its says a message like memory full but i have aenough memory in my memory card and phone memory. i can't receive anything from other mobile via bluetooth. please please help me.....
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Nokia Master 1,001 Answers
  • Posted on Jan 12, 2017
wwlvictoria
Nokia Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603668
Points
6027
Portable Bluetooth 4.1 Receiver Wireless Multipoint Connection Audio Music Adapter with 3.5mm AUX Port and Hands Free Calling for Home Audio Music Streaming Sound System https://www.amazon.com/Charm-Bluetooth-Multipoint-Connection-Streaming/dp/B01G8219Y4/ref=sr_1_4?ie=UTF8&qid=1484186120&sr=8-4&keywords=Charm+sonic
Anonymous
Level 2:
Sniper:
  • Expert 78 Answers
  • Posted on Jan 04, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
78
Questions
Helped
25890
Points
341
When transfering dta from another phone by bluetooth it asks for the password usually 1-4 numbers to confirm authencity just enter 0 in your phone and 0 in the other phone when password is aksed for an easy solution . When you receive Mp3 or Video via bluetooth it's received a message and stored in your phone's main memory . Go to Messaging and setting and change default storage location to Memeory Card , don;t forget to copy all your messages when asked . Now you can utlizie the memory card for media received by bluetooth
I am trying to send a photo from my mobile to another mobile. Mobile is Samsung E2510
Hello there,
You can send the photo via bluetooth provided the person you are trying to send it to is close to you. All you need to do is to turn on the bluetooth of the phone and turn on the bluetooth on the receivers phone, then you select the photo you want to send, then you select the options and select send, it will ask how you want to send it, select via bluetooth, then it will search for the xevice you are trying to send it to, then the mobile you want to send it to will be visible on your bluetooth list, then you select it and send the photo, it will load a page and send the picture for you.
You can also send the picture using mms, that way you will have to set the configuration settings on your phone to do so.
You need to have the internet and mms configuration settings of your phone before you will be able to send or receive any mms.
Contact the customer care of the sim service provider so as to know the settings, they can configure it for you automatically, of give you a manual settings information also, they can give you a short code that will give you easy activation access.
Thank you for using fixya
Caseytech
1helpful
2answers
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you
select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed
My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running
on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery
application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon,
the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already
exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the
devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new
search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to
be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and
the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a
passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device
to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the
device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via
Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the
devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for
both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is
shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the
message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
1helpful
Hi i just bought a lg gw300 and i can't set up my bluetooth i don't know how to set up the "passcode".
Your "Passcode" is setup when you "Pair" with another Bluetooth appliance.
e.g If you want to connect to your friends phone via bluetooth to send a picture you would send via bluetooth and search for bluetooth device. When you select the one you wish to connect to it will attempt to "Pair" with it. At this point a "Passcode" maybe asked for if the bluetooth device you are pairing with has one set. If it does then you need to ask the person who owns the device for the "Passcode" before your picture can be sent/recieved.
Normally if you wish to set a passcode for your device it will either be in your bluetooth settings. Possibly even in "Security" in the bluetooth settings or it may just be in your "Security" settings.
61helpful
2answers
Cannot connect via bluetooth to Mac
The default passcode for the Pogo is 6000.
Sam
I can't receive any mp3 songs and pictures via bluetooth
when it ask passcode, its an security protection, u'll just have to input any number, and same as to the other phone. like 1234 and you'll input the 1234 passcode on which phone you are pairing with, try changing you setting in your message setting cause, mostly when via blue tooth it stores on your inbox.
I can't receive any pictures or songs etc... via bluetooth
Hi! When it asks for a passcode enter 0000 as passcode, it will also ask a passcode from the phone from which you are recieving the files and on that phone enter 0000 as passcode and it will let you recieve the files.
Forgot my passcode for my bluetooth
base on my experience on using the bluetooth on any mobile phone.. there is no permanent passcode in it.. you can set any passcode everytime you make a connection to another phone.. if someone you know sent you a file thru bluetooth the connection will ask a passcode from then you type any passcode then make sure you tell the sender what password you set on your bluetooth to make the connection..
Device List - Bluetooth
u can select " always allow" option. But before connecting every mobile want a code to which mobile u want connect
23helpful
5answers
Forgotten bluetooth passcode
CupidsEnemy - passcode 0000 try that...it will work
Guest - just connect and when ask for passcode type 0000
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
