Can't get camera to focus sharply.
Hi!
Make sure your lens is clean and free of any smudges or debris.
Ensure that you are far enough away from your subject that the minimum focusing distance has been achieved
Most auto-focus systems use contrast to detect what needs to be sharp. If you are shooting something that is all the same color, the camera will probably not be able to focus.
Make sure there is plenty of light on the subject; even if to the naked eye it looks like there is light, the camera focus system will have a hard time detecting your subject if it is not extremely well lit.
Hope that helps!
SOURCE: canon powershot a85- blurry images
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
SOURCE: canon powershot a85-blurry photos on AUTO
SOURCE: blurry image on LCD and blurry image recorded on CF card
I had the same problem. It got corrected when I turned off several options in the menu, and later turned them back on. I have left the assist beam and AiAF off and it works fine.
SOURCE: Canon PowerShot A720 IS - "Lens error, restart camera".
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: My Canon PowerShot SD1000 won't focus. Most
View is not get displaying in the screen when i select other than Easy mode.If i select auto mode it is displaying only the black screen.Any idea why it is like this?
