Driver not found
Thank you man but these keys didn't work for me. Guys you can go to https://plus.google.com/103156713044838092165/posts/WBduJyEaG5v to get genuine win 8 keys in a cheap price, I got one there several days ago, it's not bad.
SOURCE: Sharp AR - M161 Copier Driver for Vista
There is a vista driver available for that model as long as you are talking about the M161 not 161. Do you have the optional print kit installed or only parallel interface. If you only have the parallel connection it requires the GDI driver which can be downloaded from Sharpusa.com under support then type your model and select OS and driver type GDI
Hope this helps,
TankMurdock
SOURCE: i have a sharp ar-m161 but ihave no drivar so if
go to www.sharp.net.au
select the support link on the banner at the top of the page
select software and drivers from the download centre box. This will open a new window. On the left of the screen select Photocopiers. From the drop down menu select your model, ARM 160 will be OK for this machine. Click on GO and select youe operating system and then this will open the drivers available. Depending on your configuration and requirements select the driver and download it. If you are unsure about what driver then the PCL/PS drivers are a good bet for network printing. If you are using a USB connection you will have to download the Button Manager as well.
SOURCE: I need Vista 64-bit Edition drivers for a SHARP AR-M207
Select your model, and then "GPD_PCL6" from the drop "driver type" down menu here:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
SOURCE: how can download sharp ar-m161 printer driver for
This model isnt work under Windows 7; accorditng whti the specs from Sharp Printer site...
Supported OS: Windows 98/Me, Windows XP (Home/Professional), Windows 2000 (Professional)
I know that this information dont solve it, but is that have it.
