THE CONNECTION ON THE PHONE THAT YOU PLUG THE CHARGER INTO DOESN'T SEEM TO CONNECT, REDLIGHT WILL NOT COME ON.
SOURCE: phone says unable to charge
Try a different battery. If that doesnt work, it may be your charger port. Take an old tooth brush, turn off the phone spray alcahol on the toothbrush, and scrub the port on the phone. If that fails your charger port needs to be replaced. Check with your provider about the warranty. If its not under warranty, check my profile and we can help you for sure.
SOURCE: Battery
you have to get you charging port replaced, take the phone to a mobile service center or mobile technician close to you and have them service it for you.
SOURCE: Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
SOURCE: My Voyager won't charge.
This happened to me last week. The pins inside your charger port must have been shifted (pushed up or down). The plug, once inserted does not go all the way through or is not fully inserted within the port. To fix this, get a butter knife (this is what I used) or something flat and skinny that would fit into the port. Then, push it down or up to the middle. Try connecting the plug and check if it's now charging. I hope this works and helps you.
SOURCE: phone won't charge or hold a charge - tried 3
The problem with the phone is the charging port since you have use different charger and you have even change the battery and yet not still charging. it means the charging port of your phone is the problem.
All you need to do i to replace the charging port on your phone and you will see that your phone will charge.
Replace the charging port on your phone and your phone will start to charge, just change the charging and the problem is solved.
Take care.
