I have used it before. It is connected via USB. I have tried using different ports and also using other devices throught these ports and they work fine. But I cannot get my PC to notice when my camera is plugged in.
The camera, when connected and turned on comes up that it is connected, but my computer wont acknowledge it.
I have tried downloading the drivers and reinstalling them, no luck there either.
Help!!
Oh, I am using windows XP.
Suggest that you go tp my computer as the answer above has suggested and attempt to open drive(memory chip) in the camera and download. If not suggest removing the memory chip from the camera and try accessing via Walmart or other stores photo Kiosk.
Suggest opening Fin-pix first before connecting camera.
Through fine-pix search for camera as if it was an external drive. Hope this helps?
SOURCE: cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
SOURCE: can't get my computer (win xp) to detect my finepix camera
Sounds like there is no connection between your camera and your pc.
Try another USB port on your PC.
You actually do not require a driver for XP.
XP will automatically detect the camera. SP2 + 3
If all fails, get a card reader.
SOURCE: Finepix J12 cannot upload photos onto computer.
Here's the best solution. Get a card reader for your card (available at Walmart, Kmart, Best Buy, etc.) and use it to download your pics to a folder you create on your desktop. Once there, you can do anything you like with them.
SOURCE: When connecting camera to computer via usb message
Do what the pros do...use a card reader instead of your camera.
SOURCE: my finepix f20 is not being recognised when I plug
Same problem, except I'm using vista. Originally camera wouldn't be recognised in the manual way so I had to copy and paste photos manually via "My Computer" etc. Now I can't even access the photo's via that. :(
