I need some help please. Even when I am printing a document, my hold button remains on with a 1 in the background and an exclamation mark. I guess this is suggesting that a document is on hold.
I got the same thing when I carried my mac in the office and hooked up to the HP Laserjet 2600n but I was unable to print due to the hold.
But when I took it home and hooked up the deskjet...there was the hold, however the documents print but very slowly
This error occurs when your printer is dealing with a particually complicated print job and cannot process it all. Try to reduce the complexity of your document or cut the print resolution. It may be worth trying to print the document in several parts if at all possible.
To print the background in your document, do the following:
1) Open the word document and go to File->Print.
2) When the print window comes up, click the option button at the bottom.
3) Then,tick the Background colors and images as shown in the attach picture.
4) Click OK.Then Click OK again to Print.
You don't specify from which application are you printing, or even what operating system are we talking about. If it's Windows, then you need to open your document, hit Ctrl+P or choose File->Print from the menu, and in the Print dialog that appears specify "1 - 44" in the Pages field. Finally confirm by clicking OK.
Please come back and leave a rating/testimonial if helped.
You can try these steps and let me know the result.
=== Problem Printing from Adobe ===
1. Open PDF document. 2. Click on 'File' menu. 3. Click on 'Print'. Print window will open up. 4. Click on 'Advanced' button on the left bottom of the popup window. 5. Put a check mark next to 'Print as image'. 6. Click on 'OK'. 7. Select the 'Current Page' from the 'Print Range' option. 8. Click on 'OK' to print one page of the document and see.
=== Enable Background Services ===
Background Services to reduce the memory for printing issues from applications like Adobe, Power Point,etc.,
1. Click on 'Start'. 2. Right click on 'My Computer'. 3. Click on 'Properties'. 4. Click on 'Advanced' tab. 5. Click on 'Settings' under 'Performance' Settings. 6. Click on 'Advanced' tab in 'Performance options' window. 7. Select 'Background Services' for 'Processor Sceduling'. 8. Click on 'Apply', then 'OK'. 9. Click on 'ok' button on 'System Properties' windows.
Try cleaning the ETB. Go to the secondary service menu (press the left arrow and stop buttons on the panel simultaneously until you see the secondary service menu), press the left button until you see "Clean ETB," then press the green check button to start the cleaning. You may need to do this several times to get it clean.
Printing Directly onto a CD or DVD in Roxio Express Labeler
Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
Click
Start
, click
All Programs
, click
Roxio
, and then click
Roxio Express Labeler v3
Click
Disk Label
, then click
Options
Figure 1: Options1 - Options button
The Options screen appears.
Figure 2: Options screen
Make sure that
LightScribe 12cm Disc
is selected from the
Disc Label
menu, then click
OK
to return to the Roxio Express Labeler window.
Click
Disc Titles
, type the title and subtitle for the CD or DVD, and then click
OK
Figure 3: Disc Title option1 - Disc Titles buttonFigure 4: Edit Disc Title screen
Click
Background
, then click
Import Background
to use an image on the computer as the background on the CD or DVD. Click
OK
Figure 5: Background option1 - Background button
Insert
a LightScribe CD or DVD into the LightScribe drive of the product. Make
sure that the label side of the disc is facing down.
In the Roxio Express Labeler window, click
Print
. The LightScribe label is printed on the CD or DVD.
Figure 6: Print1 - Print button
There could be a setting in your scanner drivers to fix that. It would be under background settings.
The other thing you can do is preview the document first and select the area you want to scan. Then press the scan button again. That way the black background that isn't needed will not print.
NV RAM and HD To initialize NVRAM 1. Remove any installed accessories (for example, a stapler/stacker). 2. Turn the printer off. 3. Hold down the DOWN ARROW ( ) button, and then turn the printer on. Continue holding down the DOWN ARROW ( ) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. 4. Press the UP ARROW ( ) button. 5. Press the PAUSE/RESUME button. The display should show SKIP DISK LOAD. 6. Press the UP ARROW ( ) button until NVRAM INIT is highlighted. 7. Press the SELECT ( ) button. The printer initializes NVRAM and then continues its poweron sequence. Hard-disk initialization CAUTION A hard-disk initialization erases and reformats the printer hard disk. Perform a hard-disk initialization only if an error code on the control panel indicates an EIO disk error. Always try initializing the hard disk before replacing it. NOTE Before performing a hard-disk initialization, print a menu map and a configuration page (see Menu map and Configuration page). Use the information on the configuration page to reset any customer-set printer configuration values that the hard-disk initialization procedure changes. To initialize the hard disk 1. Turn the printer off. 2. Hold down the PAUSE/RESUME button, and then turn the printer on. Continue holding down the PAUSE/RESUME button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. 3. Press the BACK ARROW ( ) button. The display should show INITIALIZE DISK. 4. Press the SELECT ( ) button. The printer initializes the hard disk and continues its power
