Philips DVD/VCR Player DVP3150V code for RCA universal remote
I have a Philips DVD/VCR player DVP 3150v with a lost remote control. I purchased an RCA universal remote. What code would I use to configure the remote to the DVD/VCR?
Your DVD/VCR player does not have a volume but your TV will control the volume for it. If you do not hear any thing is because you did not hook up the TV right.
how to hook up a DVD player to a TV - http://www.youtube.com/watch?v=fVWE4_Vyesg
Collect together the manuals or model numbers of all the items you want the universal remote to control. You will need to know manufacturer's name and the model number of the product. You will also need the owner's manual for the Universal Remote
Find the codes for the devices that you want to operate. The codes are located in the Owner's manual for your remote. Be sure to match the codes up with the exact model number of the item that you are trying to operate. Each item must be set up and programmed into the remote individually.
Program the devices by this guideline for the process. These will be different with each model of remote chosen but this is the general procedure, so you know what to expect. To program a TV into the remote perform the following: Press and hold the code button on the remote until it stops flashing. Press and release the Code button and select the device this is for, and enter the three digit code for the manufacturer and model number of your device. With the device on, press the Channel UP key and see if the channel changes. You are done with that device if the channel changes. Repeat the process for each of the other devices.
Hi, try following codes RCA universal remote controller: 021, 022, 062, 096, 124(VCR) 162, 356, 357(DVD) Philips Magnavox Universal Remote PM335 130 226 330 536 631 734 738(VCR) 441 442 943(DVD) many direct codes doesn't work ,code searching method all ways work better but irritating STEPS: 1. Press and hold CODE SEARCH until the INDICATOR LIGHT lights, then release CODE SEARCH. 2. Press and release the device button for the device’s code you are retrieving (TV,VCR or DBS•CABLE). The INDICATOR LIGHT will blink once then remain lit. Note: For AUX, press DVD•AUX then the device button for the code you are retrieving. 3. Press and release CODE SEARCH. The INDICATOR LIGHT will turn off. 4. Starting with 0 on the keypad, press the number buttons in order (0-9) until the INDICATOR LIGHT blinks. 5. The number which causes the INDICATOR LIGHT to blink is the first digit of your code. 6. Repeat step 4 until you have retrieved all three numbers in code NOTE: if any of the above works note down code used in small bit of paper and place it in the battery chamber(safe place)
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
I guess, the easiest way to go is to get an universal remote control and try codes from the provided list until you run into a working one. Many universal remotes have a mode when you can try to click tens or hundreds time on a button (like UP button) until it accepts the code.
