I just bought a HTR-6130. I connected my video projector into the composite monitor out jacks in the back of the unit and all I get is a black screen. I would usually get a no signal from the projector if no signal was coming through but that is not the case, it is just black with the composite tag on the bottom left. I hook it back up to my dvd player's component video connectors and the there is no problem. Please help.
SOURCE: Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
SOURCE: changing the component input to composite or s-video output
It will not work. This unit can not convert video signal from component to s-video. Use the same type of connections on DVD and TV.
This answer is not true. The Wii is capable of 480p video over component cable, but also 480i or 576i works fine over component. But I have the same problem that my Yamaha receiver has no picture with the Wii set on 480p. 480i (60hz) and 576i (50hz) works fine over the component cable!? Any (other) advise how to fix this?
