I didn't get any instructions either with the Blue Hat Bank, and my little boy can't deposit his coins. uhhhhh....some incentive. Anybody know how to get into the thing? It keeps asking for a pin, but won't let you create one???I didn't get any instructions either with the Blue Hat Bank, and my little boy can't deposit his coins. uhhhhh....some incentive. Anybody know how to get into the thing? It keeps asking for a pin, but won't let you create one???
I am having the same problem and I have been looking online and the company Blue Hat does not even have their own website to go and print a manual
AnonymousMar 16, 2014
I dont know how to reset the code from the 1234 setting. This bank only types numbers. Plz help!I dont know how to reset the code from the 1234 setting. This bank only types numbers. Plz help!
You can't post conmments that contain an email address.
Take the batteries out and reinsert. Will reset pin to 1234. Also reset button on back, (little round hole) next to battery compartment, use a pen to reset it.
The only solution I have found is to press the reset button on the back of the bank. You cant change the pin number unless you already know the currend pin number. After the correct pin number is entered press enter, change the pin number, then push enter again.
If it has a reset button on the bottom, it might work like my child's Discovery Toys safe, which is also like the Summit Toys safe: When you press the reset button on the bottom of the safe, the code defaults to "1234". To set a new code, Press *, then your four-digit code, then * again.
It sounds like you want to reset the PIN (personal identification number) for your U-count account. The specific steps to do this will depend on how you use your U-count account and how the PIN was set up. Here are some general steps you can try:
Check the U-count website or app for a "forgot PIN" or "reset PIN" option. Many accounts have a feature that allows you to reset your PIN if you have forgotten it or want to change it.
Contact U-count customer support. They may be able to reset your PIN for you or provide you with instructions on how to do it.
Check the manual or documentation that came with your U-count account. It may have instructions on how to reset the PIN.
If you set up your U-count account through a bank or financial institution, you may need to contact them to reset the PIN. They should be able to provide you with instructions on how to do this.
I hope this helps! Let me know if you have any other questions.
No, it is not possible. Since the records is with your bank - the other bank ATM will not accept this option. Therefore, you cannot use other bank ATM to change the pin. Even when you receive the debit card first time, you have to activate your card in the ATM of your bank only initially and not with another bank ATM
First you
need to buy a hat pin and the beads that you want to use in your hat pin.
Decide what order you want them to appear and thread them onto the hat pin.
Then use a crimping bead to hold all the other beads in place and use pliers to
tighten it so nothing will fall off.
It's really
as simple as that and if you bulk buy the hat pins, it can be a really cost
effective way to match the pins to your clothing.
To set clock: Turn off laptop. Hold down the "clock" key as you turn on the laptop. Use "forward" and "back" keys to change time, "enter" to accept changes.
We have the same atm/bank for our son. Here's the fix:
1 - push the reset button on the back of the ATM near the battery compartment.
2 - insert the ATM card and press the BALANCE button to change the user name (need to do this before getting to the pin)
3 - enter your childs name and push enter when complete. Cancel will delete an incorrect letter.
4- enter the default pin (1234) - this will bring up the DEPOSIT, WITHDRAWL, BALANCE screen.
5 - Press ENTER and it will show the current/default pin. Input the new pin number you desire and press ENTER again.
ok i hit the rest button on the back of the machine and it erased all my memory off of it so i had to reprogram it .If u put 1234 in as a pin # it will open then press balance and hit enter and u can change your pin # there .
I sent an email to [email protected] which is customer service for Blue Hat Toy Company. She emailed me a PDF file manual for the Teach and Talk Laptop. Without the manual you would never be able to get the game functions figured out.....
If you need the manual I would be happy to forward the pdf file to you.
