Air Purifiers Logo
Sandro Posted on Oct 31, 2012
Power Switch is stuck..
Appears that power switch is pressed in. Fortunately it is in the on position and will not turn off. How do I replace the switch? Suggestion on where to get Miele parts?
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
5helpful
My XL-15 won't power up. Everything seems to be in place but when I flip the power switch to the on position, nothing happens. I have looked at the fuse and it looks ok. Could there be another...
Hi Jan,
If the fuse is good and you are sure your outlet has power, then check the safety switch is being depressed. On the back is the lint screen, there should be a clip that depresses the switch. Hope this helps you.
How do you turn off the little red filter llight above the low speed indicator?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
8helpful
I have a constantly blinking red light above the lower setting arrow...how do i resolve the problem???
2answers
Replace air filter warning light to reset?
Blinking red light above the lowest setting on filter queen defender air purifier.
How do you reset the red light on the defender when you put in a new filter? My light has never went out and I think it is supose to .
It won't go out by itself.
2answers
Sharper image ionic breeze air cleaner
I was able to find the power-on switch to be defective. The switch is a momentary normally off switch constructed of two contacts on a printed circuit board1.gif. After five years, the surface of the switch contacts became oxidized and no longer made electrical continuity when depressed. I rewired the two wires to a new momentary switch and both my Ionic Air Cleaners are working again.
38helpful
3answers
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Top Miele Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Miele Air Purifier Expert? Answer questions, earn points and help others
