SOURCE: myTouch 3g SLIDE. I bought
ok, now, you need to get the settings from them then enter them manually following the below procedure.
1 Press HOME, then press MENU, and then
touch Settings. 2 Touch Wireless Controls > Mobile
networks > Network operators or Access Point Names. To create a new access point 1 Press HOME, then press MENU, and then
networks > Access Point Names. 3 On the APNs screen, press MENU and then
touch New APN. 4 In the Edit access point screen, enter the APN
settings. Touch the APN setting item to edit it. 5 Press MENU and then touch Save when
you finish setting up the new APN.
SOURCE: i have HTC Magic My
For reset follow
Reset
- clear storage 278 page
- hard reset 277 page
- soft reset277 page
Download the htc touch hd smartphone user guide manual-->click here to download
http://member.america.htc.com/download/web_materials/Manual/HTC_Touch_HD/081023_Blackstone_HTC_English_UM.pdf
It is in pdf format,you need adobe reader.Go to www.adobe.com
http://www.adobe.com/
if you don't have thesoftware. Hope this helps,
SOURCE: My LG KM900 is running
Hello thanks for using FixYa
To become your LG KM900 faster. Try to reset it. It will surely become faster in use by doing this
To hard reset of your cell
Type 1809#*500# & select reset option which restores the factory settings. it will ask you to confirm that press Confirm. it will take some time and your handset will be restored to original settings
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Please note that all data will be deleted from the HTC myTouch 3G as a result of this procedure. This process does NOT delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding.
All data including third-party applications will be deleted from the HTC myTouch 3G. Once the wipe is complete, the phone will reboot to its factory fresh state.
Published on May 13, 2010
The HTC myTouch 3G is highly customizable and you have been hard at work tweaking it to your liking, but now the fun is over and you want to return it to its factory settings again.
Here, we show you how to hard reset the HTC myTouch 3G with step by step instructions.
This will restore you setting. You will lose anything not stored to google or your SD card. But your phone will work again.
