I have tried to play this game bt it doesnt work and was wondering how i can get it to work
SOURCE: Playing high graphics games on acer aspire 4315
Check the requirements printed at the back of each game. this will tell you if the game runs. If some game is slow try disabling the antivirus while you run the game, remember to restart antivirus afterward.
Do not use software accelerator, majority of them are useless, some of them carries malaware and viruses.
SOURCE: d2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Good luck and Merry Christams
SOURCE: acer aspire one - its died!!!
I have a problem with my Acer Aspire 3100: This is what shows on the screen;
Phoenix Trustedcore (tm) NB
Copyright 1985 - 2005 Phoenix Technologies Ltd
All Right Reserved
System BIOS Version: v2.83
VGA BIOS Version: ATI UMA V008.0501.017.000.18675
CPUO = MOBILE AMD Sempron (tm) Processor 3500+
640K System RAM Passed
446M Extended RAM Passed
512KB L2 Cache
System BIOS Shadowed
Video BIOS shadowed
ATAI CD-ROM: Optiarc CD-RW CRX880A
Fixed Disk 0 : Hitachii HT S541680J9SA00
Mouse initialized
Error
0280: Previous boot incomplete - Default Configuration
Used
Can anyone help me please?
Damie
SOURCE: aspire 4520 epower management DMC has stopped working
uninstall any game recently installed (cossacks).
SOURCE: Hi - I have an Acer Aspire One netbook & Acer Game problem
Try this I think this game is made by the same people so it might work
1. After installing, go to the desktop.
2. Right-click on the Blackwell Legacy icon. Select "Open file location" to go to the program folder.
3. Find the program called "winsetup.exe" and run it.
4. Select the checkbox that says "Run in a window instead of full-screen".
5. Don't change any other options. Click Save, then exit.
Try running it in compatibility mode.
