Boating Logo
Anonymous Posted on Oct 31, 2012
Outboard 115 yamaha misfiring at low revs
Misfiring at low revs and ok at high revs
paul
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Clymer Master 1,190 Answers
  • Posted on Jun 04, 2014
paul
Clymer Master
Level 3:
Renaissance:
Answers
1190
Questions
Helped
264234
Points
1883
Clean carbs and check set up !
2 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 13, 2011
SOURCE: yamaha outboard saltwater series too much
too much oil in mix---- their is a pump for supplying the oil and something is up with this .now what i have found is their is a brass type jet in the outlet and this is no doubt missing but its not a big problem just mix the oil into the petrol ,easy but the air leak is a another problem as this is a fault with the reed valves which sit in the inlet manifold ,if you remove the manifold you will find a set of metal reed valves and they could just need cleaning ,Its a fairly common fault where their is a ingress of salt water from spray and if they are beyond cleaning then you will just have to renew them easy to do but not cheap .What i used to do with my mercury 2T engine was to put a about half a litre of diesel into a tank of fuel with the oil ,now i know it smells but i found this kept the top crank bearing lubricated ,I now have a 4 stroke engine and its superior in every way and uses less than a third of the fuel for the 2T
Anonymous
  • 184 Answers
  • Posted on Nov 29, 2012
SOURCE: 115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit r
sounds like a bad coil or trigger. Find the offending cylinder with a timing light and physically move the coil to a good firing cylinder. If the problem follows the coil, you have it, if not you need a trigger,
115 yamaha sho vmax over 3500 rpm it reves up and down under 2400 it stays even rpm. 2017 yr.
If your 115 Yamaha SHO VMAX outboard engine is experiencing RPM fluctuations at speeds over 3500 RPM, it may be due to a few different factors. Here are some things to check:
  1. Fuel supply: Make sure that the fuel supply to the engine is consistent and free from any debris or obstructions. Check the fuel filters, fuel lines, and fuel pump for any signs of damage or clogging.
  2. Spark plugs: Check the spark plugs to make sure they are clean and functioning properly. If the spark plugs are worn or dirty, they may cause the engine to misfire at higher RPMs.
  3. Throttle position sensor: The throttle position sensor (TPS) sends a signal to the engine control module (ECM) to adjust the fuel and air mixture. If the TPS is not functioning correctly, it may cause the engine to fluctuate at higher RPMs.
  4. Air intake system: Make sure that the air intake system is clean and free from any debris or obstructions. Check the air filter and air intake hoses for any signs of damage or clogging.
  5. ECM software updates: Check with your Yamaha dealer to see if there are any available software updates for the ECM that may improve the engine's performance.
If you are unable to diagnose and fix the issue on your own, it may be necessary to take the engine to a professional technician for further diagnosis and repair.
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Free outboard repair manuals
very basic carbs ! clean all jets and emulsion tube then check the float needle is clean and the tip isnt grooved , blow threw all ports etc and then refit and set the mix screw 1.5 turns out for starters then run up in a tub of water and fine tune till its happy to idle and rev up ! make of engine ??
Yamaha 4HP outboard - cannot pull starter cord - jammed.
Engine or gearcase seized...
Remove the recoil starter ( 3 bolts and the startingear link)
If you can turn the flywheel slightly: Gearcase seized
If you can't turn the flywheel at all: Engine seized.
In both cases: If you can't disassemble and have the job done yourself, forget that motor...
1helpful
115hp 1985 yamaha outboard 6e5 AETO running at low revs as if on 3 cylinders,on low revs only when i accelerate it goes well and fast without issues,when i slow to trolling speeds it runs a bit rough...
Unscrew the 4 idle mixture screws 1/2 turn 1 at the time till sneezing stops...
Clean your carburettors
1helpful
Top Clymer Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Clymer Boating Expert? Answer questions, earn points and help others
