Whirlpool LER4634EQ2 electric dryer,makes humming noise when door closes, heating element gets really hot, but start button doesn't move drum, then heating element shuts itself off
See if you can spin the drum with little resistance or is it really hard to spin?
The drum spins without much effort. I've read that this may indicate that the belt is broken. Is that correct?
I take that back. I popped the top and the belt appears to be fine.
You have a bad start relay on the motor and you need to replace the motor. The relay is not sold separate. Here is the motor you need. http://click.linksynergy.com/fs-bin/clic...
SOURCE: whirlpool Cabrio electric dryer
ctwoods, this sounds like the heating element has shorted to the heater can. What that is doing is leaving the element at 1/2 power on all the time. If this happened, then the heat kept going up until it blew the thermal fuse which caused the motor not to run. So check the heater and any fuses in the dryer. You can go to Service Matters for Whirlpool Service Manuals on this model.
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
SOURCE: Electric Clothes Dryer Problem
if the dryer worked fine before with the element not staying on when you open the door, etc, then what you have done is a very common mistake to make, you must have dislodged a wire off, or maybe placed one back in the wrong place, its a very easy error to make, which is why when removing parts for repair on any appliance you must make very detailed notes, better still take digital photographs with a digital camera double check any wires etc, don't worry i am a retired appliance engineer and even we can make this mistake
SOURCE: Whirlpool Dryer LER4634EQ2
you can remove the back panel everything is acessed from ther, with a meter you can check for continuity of all the thermoats and heater assy, first one to check is the thermal overload fuse locate d in the middle of unit "white " usually blows when excessive temp is detected( blocked vent)
SOURCE: Simpson Sirocco 350 Dryer not heating
I repaired my broken fan belt with a drop of super glue - there is virtually no load on the belt and it now works perfectly again. A 30 sec quick fix.
