Question about Mitsubishi WS-55511 55" Rear Projection Television
Help my ws-55511 can anyone help me with this.
Ok i have replaced the caps on the dm board and tested taht the caps are not bad. Can anyone else help me with this. i have the syomptom of it turning on and then 3-5 secs later shutting off. Please help me with this less then 4 yr old tv.
    Genius:
  • 1,694 Answers
Changing caps on DM board is good prevent maintenance,
 but does not represent the solution...DM caps symptom is
 Continuos blinking light.
 See    " problem 351"    On 10/20   WS 55908  comments.
  Let me know....T.
Posted on Oct 20, 2007
SOURCE:
My Mitsubishi WS-65613 has the green blinking light of death
Did you replace the caps in the dm board? or power supply? If you did not replace them on the DM board then do so. If you have, then it is time to replace the DM board. Part# 934C067001
They are in stock - about $400
Aug 23, 2012 | Mitsubishi Televison & Video
Green blinking light on wd-62725
Test the caps on the power board. tell me if the led is bloinking a number of times.
Oct 24, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52725 DLP DM board
The DM boards for that chassis are almost impossible to find if they are still good. Have you tried replacing the caps on the DM board that you have? Thats usually whats wrong are bad caps.
Mar 16, 2012 | Mitsubishi WD-52725 52". Rear Projection...
Need a wiring scematic to locate the dm module to replace caps for the microprocessors. Had a power outage the other night now the power light on the front of the set just blinks. Can anyone help me?
You need pictorial to locate dm module in tv and to replace bad capacitors.
This Link will help you to locate dm module in tv and info about what are requirements to replace bad capacitors in dm board.
Hope this will help you.
Thanks.
Dec 29, 2010 | Televison & Video
Mits WD-52525 random 1-pixel jitter
if you are a profetional replaced all capacitors on FMT and DM board.. or replaced the chassis........
DM and FMT board N/L/A .........
Jun 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ws-55511 DM 5volts draged down blinking led
Did you check the caps on the DM board? They usually go bad after a period of time. Remove the DM board and the metallic cover and there should be 4 to 7 capacitors (There are different revisions of the DM board). Check these caps also, replace if needed.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS 55809 Rear projection TV
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 16, 2008 | Mitsubishi WS-55513 55" Rear Projection...
65" Mitsu with 55" DM ?
I would go for changing the capacitors I have seen many that have the same scenario.95 % of the time it falls back to capacitors being bad on the board. I have also seen alot of boards interchanged in the projection units. Has it ever been in for service? If so was it performed byan authorized mitsubishi repair shop?
Jan 03, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Dm board mit wd52525
Sep 28, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws65611
Mitsubishi sets are notorious for leaking caps. These are the black caps labeled "Nichicon" and sometimes "Rubycon". They are easy to spot because the negative leg has what appears to be dark acid leaking down, the board has a circle of discoloring around the cap and sometimes the copper trace on the other side of the PC board is all black and contaminated. If you know what you are doing, you can remove all of these caps, clean up the board and replace with quality caps, and this usually solves the problem.
Jun 27, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
132 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
