Washing Machines Logo
Posted on Jan 03, 2009
What is the drum capacity size on the orig maytag neptune washer?
I cannot seem to locate a tag with such information
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6923
Points
14
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6487
Points
What is the capacity or drum size of my frigidaire dryer model GLER331AS2.
NF code may tag neptune front loader!
www.fixya.com > ... > Neptune > Maytag Neptune MAH5500B Front Load Washer
Apr 14, 2009 - CODE IN MAYTAG WASHING MACHINE Hello & Welcome to FixYa NF error in yourMaytag is displayed due to no fill condition, when the washer tries to fill but ... SOLVED: Maytag Neptune MAH6500AWW '03 front ...
Nov 9, 2016
SOLVED: HOW TO FIX NF CODE IN MAYTAG ...
Oct 2, 2011
SOLVED: Machine is flashing nF code
Jul 13, 2011
Maytag Neptune MAH9700 Front Load Washer Nf code ...
Jun 21, 2011
More results from www.fixya.com
What size machine is the Neptune mah5500b?
Judith: According to eHow.com: "The washer has a volume capacity of 3.34 cubic feet. The overall depth is 28.25 inches, the overall height is 42.5 inches and the overall width is 27 inches.
Read more : http://www.ehow.com/list_7586453_maytag-neptune-5500-specs.html"
Maytag Neptune washer , when I turn it on for a 35 min wash , it works for about 12 min , then tunes off , with a lc on it , ? it just sets there and does nothing ,
"lc" may mean "load capacity" meaning too much weight in the drum. Wash time may be variable, and the load amount too! Experiment with you "wash time" feature, it may be for lighter loads ONLY. Get a user guide for your machine would be my call.....
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
Where can I find the capacity load of my washer or how big is my washer?
acording to dealtime.com the Maytag Neptune FAV6800AW Top load washer has a volume capacity of 3.5 cu/ ft; or (Depth x Hight x Width) 29.25 in x 37 in x 27.25 in.
Just trying to find out drum capacity of my maytag heavy duty super capacity 7 cycle washer. Please help
Check the tag where you find the model and serial number, they often list it there. Your owners manual should tell you as well. You might have to call whirlpool (maytag), I cannot find the capacity listed on the tech info. Good luck.
My neptune washer has water in the tub after it
You'll need to clean the strainer. It is located between the drum and the pump. and is connected to the drum with a rubber hose.
Best regards, --W/D--
The belt keeps coming off my maytag washer mo. mah55flbww. tub bearing seem good motor seems ok
That is a tough one, especially since you indicate that the bearings are okay. The belt not wanting to stay on a Maytag Neptune washer usually does not bode well. It is usually an indication that the drum bearings are shot. Look for brown splatter on the back of the drum and the inside bottom of the washer. The presence of any brown discoloration is a pretty good indicator that the bearings are going. Anyway, hope this helped, sorry for your problem, and best wishes.
2helpful
Maytag neptune washer
Drum capaicty is 3.34 for the Neptune Model # MAH4000AWW
9helpful
2answers
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
