When somone sends me a multimedia message, i get a blue box on my screen that says "unable to recieve multimedia message". I also can't access the media net feature, when i try to access this it gives me a message with a stop sign saying "packet data connection not available" then i get one saying "link not avalaible". is this something i did or is it some external source. I have had success sending/receiving messages for about a year now and this just occured in the past week. Multimedia messaging is included in my service.
For the normal at&t apn settings, or also called at&t wap settings, these are the values you should use
APN: wap.cingular
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: [email protected]
Password: cingular1
Server: <Leave in Blank>
MMSC: http://mmsc.cingular.com
MMS proxy: wireless.cingular.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
at&t apn settings 4Gdetails:
If you have a 4G phone (e.g. iPhone 5, Galaxy S4, HTC one, etc) you should try using these at&t apn settings 4G. They run faster and more stable connections.
APN: phone
Username: <Leave in Blank>
Password: <Leave in Blank>
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
APN type: default,supl,mms,hipri
Bearer: leave it to the Default one at apn settings Step by Step Configuration
SOURCE: mms
hi
have the mms settings been changed ?
can you send / recv texts ok.
you could conntact your network provider and have the settings resent to your phone .
riz.
SOURCE: Samsung Blackjack
You need to go to folders and switch to your inbox. There are 5 folders...you are probably in deleted items or sent items.
SOURCE: Can't send or receive MMS messages
I work in TSD for ATT , and from multiple cases like this , customer do not know that ATT requires that all PDA phones do require a PDA data package , without this you will not be allowed to send or receive MMS messages.
SOURCE: cant download my multimedia messages
I had the same problem, i searched and searched and finally found an answer that i was sketchy to try, but works perfectly. Go into your setting, connections, GPRS, and DELETE, yes, DELETE the AT&T option. Do a soft reset and your good to go, i've had no more problems
SOURCE: Multimedia messaging for BlackJackII
You have to do a master reset ...this WILL WORK.. I had the exact problem ..now I don't . Save all your stuff on your sim card
