Archos 504 500870 Digital Media Player Logo
Posted on Jan 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My archos 5 wont switch on to the home page
When i switch my archos 504 on it stays on the opening message(archos entertainment your way) then goes blank then just keeps repeating itself with the same message what should i do?
  • joshrush Jan 03, 2009
    my archos is the archos 5 60 gb
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
58140
Points
121
You should perform this when it is on
problem solve #1
* Press the reset button on the buttom of the device using a papr clip. It should shut it off. then try to turn it on again.
try the next if the problem still exist.
Problem solve 2
* Download the latest frimware from Archos.com on to the desktop on your computer ( i recommend desktop because it will be easy to find) Then plug the device to a pc Using USB cable. turn the archos on by holding power switch and TV/LCD buttons at the same time until a white screen comes up. it should ask for Usb. if it does pick the ubs. if it does not give you a USB option but these "NO", "REPAIRE", "FORMAT" move the curser to repaire. do not pick the format which will delete all the contents and plugins you have on your device.
after repaire completes it should say done. do not press the done wait until you see the archos connection under My computer. it should normaly come up with name 504 or you will be able to see the archos icon. place the firmware in to the main drirector not under any folder. then press the ok button to confirm the "done" device will power off and start with a white screen again but this time it will update the firmware and restart do not unplug the Usb cable until the update completes. It should restart again and load the normal user interface. Your device should be fine and back to normal.
  • Anonymous Sep 21, 2009
    If HDD is not making any noise, it is fixable mostly a corrupt file in the system or in the media library. Could be easy fix starting with trying to reset the device. If the problem still exists then update the firmware, next option will be to take the Hdd out power on the device and off without Hdd. Place the dd back in and turn it back on.This will trick the system to re recognize the HDD without the previous error.
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Sep 05, 2009
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
10481
Points
98
I think that is due to a hard drive failure in which case you would have to get a new one.
Archos 504
Go to this website and download your FREE manual in pdf form. (Opens with Adobe Reader)
Please do not forget to rate me.
http://safemanuals.com/user-guide-instructions-owner-manual/ARCHOS/504-_E
17helpful
5answers
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
504 recovery screen
hold the tv button slightly earlier than holding the power button, first tv then power (while still pressing the tv button). it should first boot up to a normal green ARCHOS screen, then it will enter the recovery mode.
Archos 504 huge problem
I had the same problem. I droped mine and it seems to have messed up my hard drive. i replaced it today and my comp. can now reconize it. i have been trying to contact tech. support to see if it is possible to get the OS back on the PMP. if the Tech support ever picks up my call i will message back with the fix.
4helpful
3answers
Archos 504 RESET button
Please open Battery cover and PRess Small Golden button just near the HDD , it will restart the Devie
2answers
I own an Archos 504, i purhcased today a DVR Station GEN 5, the box states compatibility with the 405 and 605, is it compatibble with the 504 too? could you confirm this please before i open the box many...
yes it is compatible but the remote wont work for Archos 504. also, u'll require saddle for 504(usually comes as part of package). dont try to put your archos on the dock without a saddle.
6helpful
8answers
Recovery code 4 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pc
c. connect 504 to pc and wait until pc recognise it
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
