I have a 10 year old Rail King Steamer with original Protosound. The circuit board that sits ontop of the smoke unit is fried. Tried the MTH website and couldn't register or pull up any info except for new sales. Have any idea's how to get through to their parts web page? anyone else had this problem? If not, any other websites where I can find an exploded view of my train so I can get the part number? The train is a T&P Mohawk 4-8-2, register #RK-1114LP (or 30-1114LP) L-3 Steamer. Purchased in 1998
SOURCE: part of web site cut off
there are some sites that cannot have there web page resized, and sometimes it appears that some of the page is missing because the sit was suitable to be viewed in a highr scren resolution, try changing the screen resolution of your pc to a higher one than 800 x 600, something like 1024 x 768 and you should see all the page.
SOURCE: Weather King contact info
479-648-4900 is the main line to the factory in Fort Smith Ar. Hope this helps, RepairUSA
SOURCE: Casio LK-30 Key Board Piano
I have the same problem. I was thinking one solution for us, but I don't like it might be to solder the power supply on and skip that female plug entirely. To do that, you cut the male end off the transformer/power supply wire (if you don't want to ruin your transformer/power supply you can buy another power supply at Best Buy for $10 - Dynex DX-C1109). Then strip the ends from each wire from the power supply so you have some bare wire showing on each wire. One goes on the spiral thing sticking up from the JCM470 board, the other goes anywhere you want on the red wire coming from the battery compartment. You should test before you solder to make sure you the proper one on the proper wire and that you therefore have power to the unit and it makes a sound. But its a sloppy fix. While it should work perfectly, the power pack then can't be changed unless you solder and unsolder it each time. Another solution is to find a broken LK-30 or LK-33 and rob the circuit board if it still works on the parts machine. Trouble is if you find one and its not near you it costs some money to ship these. At some point its just easier to buy a used one on Ebay or craigslist.com, I guess.
SOURCE: VinoTemp VT28TEDS - circuit board
Here is the phone number for Vinotemp International 800-777-8466 for customer service.
SOURCE: I need the controler for the SantaLand Musical Train Set
New Bright offers ONLY a 60 day replacement warranty after which there are no parts or service avaialble for this train set.
I would contact New Bright about a replacement or take it back to the store where you bought and select something other than New Bright products.
http://www.newbright.com/
