How do I actually get to the voice recordings so I can delete them without actually having to reset my entire phone? When trying to record a voice message it just says voice message full and doesn't give me an option to delete anything. Is there a place you can go on your phone to find saved voice recordings so they can be deleted manually without actually reseting or clearing the entire phone? I went to sounds already and it's not there.
Depending on how your razr is set up, you should be able to click on the "settings" button, then click the "tools" option, which will open that sub-directory, then scroll down to where it says "voice records", open that, and then click the menu bar (the one that looks like a flat bar like --- ) and then it should give you the option to delete it.
Once you delete something from a phone it's very difficult to retrieve (next to impossible actually) but their may be hope if you backed up your phone to iTunes you can go into iTunes at the main screen where it displays your phone info there will be a button to restore your phone to a previous backup (you may have to restore your phone to get the restore backup option to appear) a full tutorial can be found at the iTunes support page under backup restore PS: hopefully you backed up your phone before you trimmed your memos the backups are time stamped
How to record voice calls on samsung corby S3653? There is a voice recorder,but it does not function during calls. Which software can I use for recording voice calls?
Olympus makes a device that allows you to record telephone conversations without having to hook up anything to the actual telephone. It is called a TP-7. It connects one end to the voice recorder in the mic jack and the other end is an ear bud microphone so that you are able to record the person who you are speaking to on the telephone so that the voice recorder captures both sides of the conversation.
go to emporium.olympus.com click on the link for voice recorders select your voice recorder and then look for the TP-7.
You can delete voice recordings by simply connecting your device to your computer. Then you got to my computer, select the device,go to recordings,then voice and finally right click the recording you want to delete and click delete. That should do it!!
Hard to tell without a model number, but in general:
Connect your player to the computer.
Launch Windows Explorer.
Select and delete the unwanted music, pictures or video files under Philips. For voice recordings, select and delete the unwanted recording files in the Voice folder.
whichever it is your problem maybe because of the fact that some players have only a certain limt of space alloted for recording.for example:in a normal 1 gb player with voice recording function only about 28 hrs(approx. 128 MB ) of voice can be recorded....even if there is plenty of space left in the player the player will not record voice once the full 28 hrs has been used................This recording facility can be reused by deleting the old recorded files.....
press and hold the voice recording button (located on the right side of flip up part of screen) the list of recorded things will appear after message that voice is saved, when list appears click Options (left button with - on it located on top of keyboard) and than scroll down and select Delete All than press OK button (located in the middle of cursor buttons)
Thanks!!! It worked!!!!
