The Azimuth Dial isn't firmly attached cause altitude cannot be fixed to an angle
I am stuggling with fixing the Altitude.
the problem is that, the Azimuth Dial isn't firmly attached, there is a slight gap between Azimuth Dial the under layer where the knob is attached to it, the gap is small
but enough for the Altitude varys forth and back about 3 degrees, so after I locked the Altitute with the "altitude lock knob", the tube isn't fixed to that angle, it will fallback 2~3 degree due to the gap, the aimed target is then completely missed.
You never gave the exact model and type of telescope you own-- along with the type of MOUNT. Is this an Altitude-Azimuth type of mount; or an equatorial type mount?
sounds like the air flow is restricted and overheats using the regular fan speed.
check for air flow blockages inside and outside, filter problems, etc
The reason is linked to startup of the device probably. I have same issue.
2 ways to improve : 1/ Startup your device You need to startup device, and wait automatic change of the screen to the ride mode, from the sattellite search screen. You also can check you have more than 4 sattellites before starting a ride. Altitude can only be computed when at least 4 sattellites are synchronized. So start your device in the open air, not indoor, nor close to a building. Garmin devices start automatically and have probably a smoothing function that make altitude converge to the reality slowly from a started erroneous capture.
2/ Upload your ride on Garmin connect site, then apply altitude fix algorithm proposed. This algorithm will fix the altitude of your waypoints, both fixing pure altitude start issue, and also fixing denivellation computation, which is erroneous because of cumulation of errors.
The altitude scale on these small telescope are virtually useless and cannot help you find objects in the sky--
Don't worry about it --- just use the scope and a star chart to find things in the sky. A free monthly star chart that you can download is available here:
