Question about Nortel IP Phone 2004 NTDU92BD70E6
Ringing only no voicemail Nortel - Nortel IP Phone 2004 NTDU92BD70E6
    Scholar:
  • 277 Answers
Forward No Answer is not working or voice mail is down.
Call your office administrator or local tech to check programming on the phone system.
Posted on Nov 29, 2012
  • waldo dudz
    waldo dudz Mar 27, 2014
    I'm afraid that none of this has worked. It keeps a reporting no driver and when it searches it can't find one. I could use some help in finding a WINDOWS 7 driver. Thanks for any help you can give me.
SOURCE:
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Oct 06, 2014 | NorStar Lands Phones
Phone rings 4 times then goes to message I want it o keep ringing
Basically, you want to disable Forward No Answer to voicemail:
Feature ** CONFIG
Terminals&Sets
enter ext #
advance past Line Access to Capabilities
go to Fwd No Answer
CHANGE softkey to None
go to Fwd On Busy
Jul 01, 2014 | Nortel Lands Phones
I have 7 Nortel t7316E handsets with only one ringing on all calls received I need to program another phone to ring also so I can have another person answer phones from another extension.
You will need to change the programming for the ext that you want to have the lines appearing on.
Enter programming - Feature **266344
PW - 266344
Press the show key - (top right arroe that is lit on the display)
Enter the ext # you want to change
this will bring you to line appearance press top r arrow
line assignment press top right arrow
show line - enter 001,002 or whatever line(s) you want to ring.
press the change softkey for each line to appear and ring instead of unassigned. Press the next (bottom r arrow) to go through each line after entering 001....
then release.
*** Make sure the sets you change are not forwarded to voicemail after a certain amount of rings otherwise all calls ringing on the newly programmed set will go to that persons voicemail.
Mar 10, 2014 | Nortel Norstar 16-Line PBX Speakerphone
Nortel/Norstar ICS phone system - Calls go to wrong voicemail on calls forwarded with NA
Check the forward no answer setting for number of rings on each extension that has ringing lines. The number of rings should be more than the auto attendant is set to answer with.
Nov 01, 2013 | NorStar Lands Phones
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
Jun 23, 2010 | NorStar Meridian M7310 Phone
Nortel T3716E send calls to voicemail HELP!
Sounds like the call forward no answer isn;t set up on your extension. The first thing to do is to find out what the voice mail pilot number is. That's done by pressing feature 982. The display should say "set:xxx". The set number provided is the voicemail pilot number. Next you'll need to enter system programming. Programming is done on 7310, 7324 and 7316 type sets. Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change call forward no answer on.
Press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
Press the show key (top right arrow) .
The display say foward no answer.
press theshow key (top right arrow)..
The display should say none. Press the chng key and enter in the voice mail pilot number. press the show key again (top right arrow) To review the rings til forward. Press the chng key if you wish to change the ammount of rings til answered. Press the release key when finished
Jun 23, 2010 | NorStar T7316E Corded Phone
Checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
Sep 30, 2009 | Nortel Business Series Terminal T7208 -...
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E Voicemail
It sounds like both phones are set to ring on incoming calls and both phones are set to call forward to voice mail box with the same amount of rings . you should turn off the ringing for both phones that way it will not jump between the to mail boxes . now when a call is trans it will go to the box .
Mar 24, 2009 | NorStar T7316E Corded Phone
Cannot get nortel callpilot 100 to communicate with nortel CICS
This is the forums for Avaya, I would repost in the Nortel side. BUT, i do know the CICS needs to be of the correct revision to work with CP.
Apr 22, 2008 | Avaya Digital Systems&Adapters ( DEFINITY,...
Nortel IP Phone 2004 NTDU92BD70E6 Logo
109 people viewed this question
Top Nortel Radio Communications Experts
ka4iup
ka4iup
Norm Pearl
Harrie
Are you a Nortel Radio Communication Expert? Answer questions, earn points and help others
