Vizio L32 32 in. LCD HDTV Logo
Posted on Jan 03, 2009
Cannot program remote for tv
I have a new Vizio HDTV and cannot find the right code to program my Innovage jumbo universal remote
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
376
Points
Here are the codes from Visio's tech support line:
These are listed in order of probability and are for remotes using four digit codes. Call them if you need a three or five digit code.
1758
0178
1756
0128
0117
1017
1078
0030
0056
0205
1292
Good Luck
Living solution code to program to a Vizio
RC: Living Solutions (or Innovage) jumbo universal ...
Remote Central https://www.remotecentral.com > rc-remote > thread
Jun 10, 2007 - Hold the device button you want to program for 3 seconds & release. Push & release the power button & the red light will remain lit. Push the ...
Living Solutions Jumbo remote need codes - RC
Jan 18, 2008
RC: Living Solutions Jumbo URC - Remote Central
Jun 20, 2011
More results from www.remotecentral.com
Remote Codes / Universal Remote
Vizio https://support.vizio.com > article > Remote-Codes-Un...
Remote Codes / Universal Remote ; 2 Digit TV Remote Codes 19 ; 3 Digit TV Remote Codes 502 627 004 113 505 011 ; 4 Digit TV Remote Codes 1758 0178 1756 0128 0117
Missing: Living ‎ solution
How to Program a Living Solutions Universal Remote
Techwalla https://www.techwalla.com > Tech Support > How To
Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc.
3helpful
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
7helpful
3answers
Do you have innovage remote codes for Vizio VO320E
I don't see Vizio TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
3helpful
4answers
Codes to program Innovage Products Jumbo Universtal Remote
Innovage Jumbo remote codes for RCA TV; 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191,194.
Pansonic DVD; 175.
Pansonic VCR; 021, 060, 115, 125, 138, 148, 149.
Philips DVD; 173, 183, 198.
Bell ExpressVu; 168, 187, 194.
5helpful
3answers
Innovage products jumbo remote
need code for jumbo remote
26helpful
5answers
Instructions for Programming Innovage Jumbo Universal Remote
You can download documentation for the Innovage remote here:
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/innovage/jumbo-manual.zip&area=other
56helpful
14answers
H have the jumbo universal remote from innovage pruducts. can you e-mail me all the codes? thanj you. [email protected]
4answers
Vizio tv
i used the goldstar codes on my vizio tv and it worked
heres a list of codes
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, 172, 196
the code 004 worked on my 32' Vizio HDTV, for the Jumbo Universal Remote
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
