DO YOU HAVE A MOTHERBOARD MANUAL?.Are you sure you have power to the correct plug in on the board?some boards require more tahn one plug in.http://www.computerhope.com/comp/iwill.htm.http://www.computerhope.com/help/mb.htmhttp://www.computerhope.com/help/mb.htm#support.These links will help.I can be of further help if you have the need.RICHARDM69
If everything is installed correctly..and power supply is working..it means theres is no problem..check the panel connector in motherboard..you will see the power button/ reset button/hdd led/ power led/...you try to short the pin of power connector.
