The receiver will not stay on when connected to dish
Rdjennings10,
It does sound like there could be a power problem with the receiver. The
Dish Pro Plus LNB won't cause any issues with that receiver. If the
receiver is plugged into a power strip or surge protector, try plugging
it directly into the wall. If it is already directly into the wall, try a
different outlet if available.
If the problem persists, we will have to replace the equipment. You can
reach me at [email protected] to get that taken care of.
Tommy Faust
DISH Social Media Representative
SOURCE: Dish Network 311 Help!!!!!!!!!!!
the only way to unlock it without the code is to contact dish network
SOURCE: satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
SOURCE: I want to add a dishnetwork 311 receiver to my
I recommend it as the receiver may be non functional for sometime before you receive a new one. Another point to consider is if you purchase a receiver on E-ay there is a good chance that that receiver may have an ooutstanding balance to dish owed by its last owner which will make it useless to you unless you want to pay the bill. 311 run about 99.00 from a reputable dealer and would advise you to pursue that avenue. Thanks for using Fix Ya.
SOURCE: I have a dish network 211 receiver and the 1000.2
Hi! I will be more than glad to assist you in this concern. Lets check your cable connection first if all is connected hand tight on the back of the receiver, check the sat in connection. once your done, press the menu button on the remote, that is located on the upper left of the remote, once you have the main menu, press 6,1,1 on the remote on it will go to point dish, select check switch on the point dish screen, that is on the upper right of the screen, once you select check switch, it will go to the installation summary, you will see port1-119-ok-1k.2, port2-ok-1k.2 port3-con-1k.2, select test on the butom of the screen, it will run a test up to 3 or 4, it depends on the status of the lnbf, once its done, it will show the whole screen of installation summary, port1-119-ok-1k.2, port2-110-ok-1k.2, port3-129-ok-1k.2, once you see these, the problem is fix and you need to select done and it will go back to the point dish, select done, it will show you an option on the screen, then press 0, 3 times on the remote to exist all the way out, it will go to a pic or it will show attention 015, let the progress fiish and let the programming download finish as well. that will fix the problem, just incase still no 129, please unplug the power of the box from the power outlet for 1minute, plug in then you will see attention 015, press the menu button again from the remote, once you see main menu, press on the remote, 6, 1, 3, check on the field g, 119-green, 110-green, 129-green, if you got 129-green, that fix the problem, in case there is no 129, please call 1-800-333-3474, call the tech support of dish network, ask for a service call and inform them that what you did, sometimes they will ask some information, just answer the question, that is only to verify the steps that you did, If 129 sat orbital location is needed on your programming bcoz you have an hd program or your local package broadcast on 129 sat orbital location, they will setup a service call but if the sat 129 is not needed on your programming they will inform you that you dont have to worry about it. granting its needed, they will setup a service call. if you have the extended warranty plan, the service call is $29 but if you dont have, the fee is $49, the extended warranty plan is $5.99 every month. if you have any query pls feel free to get in touch..
Testimonial: "Thank you for your help. I'm thinking now that I don't need the 129 satellite for my programming. Thanks again."
