I took it apart to look at it, nothing cracked plenty of grease, must be another solution out there. Thanks for any suggestions
If you haven't solved this problem yet, I have a couple suggestions.
Take off the motor housing, be VERY careful where the exposed electrical contacts are, then plug it in and turn on the motor with no gears attached. If it spins, cycle through the speeds to make sure they all work, then if they do, revisit your gears. Turn them all by hand and make sure they move easily and smoothly. Make sure the teeth aren't too worn down. I don't know what model you have, but also check anything that holds gears on or in place to make sure they aren't loose or cracked.
If the motor does not spin, look at the brushes (you could start by doing this if you wanted to, since they are far easier to take apart than the motor housing, but my guess is this isn't the problem). If the brushes are worn down to near the spring, buy new ones. If the brushes look fine, then either get real brave and pull open the motor to look for broken or worn out parts, or call an electrical engineer friend, or send it off to kitchenaid or a repair shop.
SOURCE: Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
SOURCE: Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
SOURCE: Kitchen aid mixer, voltage issue
Why not just buy a power converter for the mixer and other electronics on Amazon. They are cheap and can be adjusted for
110 - 240 and can be used anywhere in the world.
SOURCE: Kitchen aid mixer drops metal shavings in the
Hi REDLACQUER. Sorry to hear about the metal shavings. This is probably not to best way to take iron in your diet... My first thought would be to ask if your mixer is still under warranty. If you’ve had the machine less than one year, then I’d let KA replace your mixer with a new one. However, I suspect like many who seek assistance from FIXYA.com, your mixer is out of warranty, so what can you do?
Have you been able to find exactly where the metal shavings are originating? From the symptoms you describe, it appears that the planetary/agitator shaft assembly may be rubbing against its housing and generating the metal shavings at higher speeds. Have you noticed any increased noise levels/squeaking/screeching when the planetary rotates? It’s also possible that the planetary is out of alignment and not rotating true. Could the agitator shaft been jarred or hit hard during set up or moving in or out of you storage cabinet? Or the shavings could be symptomatic of other internal gear problems, but that would be the least likely scenario as the mixers internal gears are pretty much self-contained.
The good news is that this can be troubleshot and fixed quite easily (OK, maybe with a little effort) by yourself if you are a DITY type person, and feel adventurous. However, before you start to disassemble your mixer, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, KP2671, and select the last file, KP2671XWH3.pdf (325.07 KB) listed under Parts List (24) (check to verify that it matches your mixer model).
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. I suspect your Planetary Assembly, Illus No. 15, is rubbing somewhere against its housing, Lower Gearcase, Illus. No. 24.
To gain access to these pieces you’ll need the following tools: a regular or Phillips screw driver, retaining clip pliers, and a small drift pin punch and a small hammer. You need to remove the Transmission Housing (Illus No. 7) and remove all the lubricating grease from the transmission housing and gears (when removing the grease be on the lookout for shavings in the grease which would indicate excessive gear wear). This will allow you to remove Illus No. 25, 21, 18 & 19, Retaining Clip, Bevel Gear, Retaining Pin and Worm Gear Follower, respectively.
Once you remove the Retaining Pin (Illus. No. 18) the Planetary Assembly can be tapped down through the Lower Gearcase Assembly (Illus. No 24). With the Planetary removed, you can inspect it and the inside of the Lower Gearcase to determine where the shavings originated. Be sure to look closely at the Planetary Gear in the lower gearcase as well as the Agitator Shaft Pinion Gear (Illus. No. 12). That will also identify what parts need to be replaced, which you can order online.
You’ll need to replace the grease you removed with new grease. You should use a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call). Do not try to reuse any original grease as it may have ‘debris’ in it.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
SOURCE: my kitchen aid mixer will not mix....the motor is
Hi AKRAUSSFAN, I hate it when that happens! From the description of your mixer’s symptom your mixer’s had a transmission failure in the primary gear box or the planetary gear assembly (agitator). One of the main gears has failed, hence the loss of power to the agitator, while the electric motor still runs.
The inspection and troubleshooting of the mixer transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in this case KSM190P, and then select the file under Parts List (61) KSM150PSWH0.pdf (773.44 KB) (definitely check to see if this matches your mixer).
Turn to pages 4 & 5 titled: “Case, Gearing & Planetary Unit”, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. I suspect your culprit gear is Illus. No. 6, Worm Gear, in Illus. No. 27, Worm Gear Bracket and Gear assembly. KA designs this gear to fail on purpose so the rest of the mixer will not self destruct.
Once apart you can check for any other unseemly wear and tear on the other gears, etc. You may find more parts that need replacement than just a bad worm gear. You may also want to consider replacing all the grease, particularly if there are gear particles suspended in it.
Besides needing a replacement worm gear and grease, you might consider replacing the gasket (Illus. No 15), too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
