Question about Mitsubishi WD-65833 65" HDTV
Mitsubishi wd60735 white spots apperaing - Mitsubishi WD-65833 65" HDTV
  • Mitsubishi Master
  • 8,617 Answers
Thats a very coomon problem which is caused by a failed DLP chip. The mirrors get stuck and thats what causes the white spots they will keep multiplying untill the entire screen is filled. You will need to replace the DLP chip. You can get the replacement DLP chip and illustrated instructions on how to do the repair from www.tvrepairworld.com
Posted on Oct 30, 2012
SOURCE:
Mitsubishi WD60735. Had white spots. Later lamp went. Replaced DLP Chip and lamp. Screen lights up very slightly. No sound. Green LED light is steady. Projection lamp is on. What is my problem.
Check and replace the lamp inverter too. Lamp replacement should always accompanied by the inverter too. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 01, 2017 | Mitsubishi WD60735
How do i remove the white spots on the screen of my Mitsubishi WD60C9 TV. I replaced the lamp few months ago now this. Help Pleaseeeeeeeee.
these white spots are caused by a bad DMD chip
call Mitsubishi and they will find a servicer and send the part to them for repair. You will only have to pay the labor
Oct 12, 2014 | Mitsubishi WD Televison & Video
Mitsubishi wd60735 error code 66
No such error code that I can find, try to unplug and let it fail again, then do the check again.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
52 mitsubishi has small white dots of light that dont go away on most of the screen
Mitsubishi is replacing these DMD IC chips nationwide under an unannounced kind of recall for model #'s WD60C9, WD73733, WD57734, WDY657, WD73734, WD65735, WD60735, WD65C9, WD73840, WD65833, WD65733, WD73735, WD73833, WD57733, WD65734 and others. Call them @ 800-332-2119 and give them your model, serial # and date of purchase, tell them you have the white spots, they will set up a workorder with a local Mitsubishi servicer to come to your home and replace the DMD chip. Mitsubishi will supply the part (part # 276P595010) for free, but you must pay $200 in labor. BUT...if you ask for Shantell Hebert when you call Mitsubishi, and really push the issue, she will also pay half of the $200 labor fee, so you go from $400 to repair to only $100. Once that chip is replaced, the unit works great again!!
Jul 19, 2012 | Mitsubishi WD-57733 57" HDTV
Mitsubishi wd60735 code 37
A 37 error code means one of your fans is bad. It would either be the DMD fan, or the lamp fan. Take the back cover off of the set and tape down your lamp safty switch. Turn the TV on and see which fan is not working, and replace.
May 17, 2012 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi model wd60735 how do I get to the lamp
If you removed the plate beneath the screen on front a door should be there or it is possible it is one with the door on back--clearly marked.
Apr 05, 2012 | Mitsubishi WD-60735 Projection Television
White spots
Replace the DLP chip at cost between $160-$300 for the part and about two hours of your own time to do it.
http://www.shopjimmy.com/samsung-mitsubishi-toshiba-4719-001997-dlp-chip.htm/
Jan 24, 2012 | Mitsubishi WD-65C9 65" DLP HDTV
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
Mirrors going bad. White and black spots are apperaing on my screen. More each day. It is my understanding that tiny mirrors are not turning off or on. Purchased DLP 46'' Samsung January 2007
Well here's the scoop. White spots mean that the mirrors are stuck "on" reflecting light. Black spots mean that other mirrors are not actuating and are not reflecting light. In any case the DMD bs or the DMD chip needs to be replaced by a trained Samsung tech only.
The DMD bd controls the DMD chip.
Jul 08, 2009 | Televison & Video
Mitsubishi WD-65833 65" HDTV Logo
367 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
