Motorola Mobility Droid X Logo
imorton Posted on Oct 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My droid x will not turn on
Phone died and now will not turn back on after being connected to a charger
Computer Repairing
Level 3:
  • Motorola Mob... Master 14,641 Answers
  • Posted on Oct 30, 2012
Computer Repairing
Level 3:
Answers
14641
Questions
0
Helped
718731
Points
53082
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
My Motorola droid razr android won't charge, but when its plugged in (original charger) the M symbol comes up and stays forever, but don't charge, and don't start s this a sign that the connection is...
Hello Sruly,
Have you try to use other chargers, if using another charger doesn't work, please feel free to CONTACT US for further assistance
Regards
Kenny
Motorola Support
1helpful
My umx droid phone battery died but now the screen wont come on
Step 1:
put your charger in your phone.
Step 2:
wait like 1 hour
Step 3:
the screen should hopefully turn on if not get a new phone.
Apr 10, 2013 • Cell Phones
I charged my droid razr maxx to 100% then battery keeps dying within 15 minutes pls help
Hello My Dear Friend:"::
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
1helpful
2answers
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
My Droid X is stuck on the Motorola "M" screen.
You may want to try a soft reset of the phone. If that does not work, try taking the battery out for a few minutes and the powering on the phone.
http://support.verizonwireless.com/clc/devices/knowledge_base.html?id=33723
Is there another way to power on a droid 2?
It's happened to me a few times recently. Simply taking out the battery, then putting it back in usually does the trick. Try plugging in the charger with the battery in. If that doesn't work, take battery out, plug in charger, then put battery back in. Hope this helps.
I let the battery die and after recharging it keeps freezing up
Hello there,
Since you let the battery die, just remove the battery and leave it for about 5 minutes, then you fix the battery back on the phone. Then you connect the charger to the phone first before connecting the charger to the power outlet, leave it for about 30 minutes, then unplug the charger from the phone and power it on, this time it will turn on properly.
When the phone turns on, ensure you delete some unnecessary files away from the phone in order to free the phones memory.
That way it wont freeze anymore.
Thank you for using fixya
Caseytech
The phone turned off and will now not power back on
probably a battery issue, is it completely empty? connect you charger, it shoul boot up and show the battery loading image... push the power button again until it shuts off again, then push power button again (long enough to see it start up) than it shoul boot again... good luck
1helpful
2answers
How to charge a motorola droid with a broken micro usb port?
You can get the usb port at Droid Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
