Behringer Ultrabass Bxl3000 300w 1x15" Bass Combo Logo
Tapi MeFife Posted on Oct 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not functioning.. I got a behringer ultrabass bxl300 for my bass ive had it for 4 months and all of a sudden the speaker starts sounding weak and it gets quieter and quieter after an hour. it would never do this before im guessing somethings not right inside of it im not a tech person or anything like that so im open for suggestion because i need this fixed asap thnx
Glen
Level 2:
  • Expert 225 Answers
  • Posted on Nov 01, 2012
Glen
Expert
Level 2:
Answers
225
Questions
0
Helped
82310
Points
395
I would check it with a different instrument cable AND bass guitar. If you end up with the same results, it's a thermal issue with the amp and will require factory authorized repair. The amp heats up and the intermittent component starts failing....more heat, more failure. It's not an easy fix and your Behringer repair shop will have their work cut out for them with this repair.
4 Related Answers
Fred Yearian
  • 5603 Answers
  • Posted on Mar 11, 2011
SOURCE: hey, just purchased some behringer
The setting of the volume controls bears LITTLE importance to the actual level the unit is being run at since one can send high levels INTO the units from the source. These are intended to be used in a studio for the audio engineer to listen to in a small room. They should really be no louder than a consumer BoomBox maximum.
A squeaking noise is not normal at a level such as mentioned however. You might see if the noise is from the speaker itself or possibly parts of the cabinet... Plastic parts are NOTED for squeeking and can be suitably lubricated.
Beyond that, since the units are new, you should be able to exercise your warranty.
Testimonial: "I have left a comment under your solution, again thanks for the advice"
Fred Yearian
  • 5603 Answers
  • Posted on Jun 07, 2010
SOURCE: Behringer's Ultrabass BXL3000 Gain knob broken
You need to replace the potentiometer with the broken shaft. You can open the unit and try to get a part number or go to Behringer parts to get an exact replacement. The pot must be matched for value, taper, and mounting and shaft dimensions.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 22, 2010
SOURCE: I've got a Behringer Ultrabass Bb410 1200w 4x10
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Fred Yearian
  • 5603 Answers
  • Posted on Aug 23, 2011
SOURCE: As soon as I turn
How do you know you are at 40 WATTS? This takes electronic test equipment to measure.
Tests to run. Observe the speaker cone with power off. Now turn it on... did it displace and stay there? If so you have a failure of the amplifier itself. Next, If you can place finger on the cone, move it gently in and out feeling for any roughness. If you feel roughness, the voice coil is fried and you be buying new speaker. A lot of the Ultra bass Behringer's use LM3886 power amp chips... sometimes in parallel, and a failure of one could cause this.
Buy input jack active model BX 4210A
Contact Behringer to get part number FIRST, then go to this website to see if they have it available. http://www.dbmproaudio.com/behrparts.html
It should be a standard 1/4" mono jack, so you can always go somewhere like Radio Shaft or PartsExpress.com and get one. You certainly don't 'HAVE' to get a certified Behringer part for this. Good luck! :)
Buy input jack
Direct out kills speaker signal on my behringer bx1200
If it's still under warranty, get it replaced. Otherwise, take to an authorized behringer repair shop, or your local pro-audio repair shop.
Foot switch appears to be wired backwards. The Shape pedal turns on the UtraBass and the UltraBass pedal turns on the Shape (Channel 2).
Foot pedals are usually NOT interchangeable... The correct footswitch would come with the amp so be sure it says Behringer on on the footswitch. Apparently some sellers have foisted off VOX footswitches which may not work with the Berhinger.
As soon as I turn the volume over approximately 40W, the speaker keeps moving while making an awful sound at the same rhythm. I believe the speak may be burned. Is there a way I can fix it or I have to...
2helpful
My Behringer Ultrabass BX600 has a very loud, constant hum. I tried a new power cord, and speaker along with checking the internal parts for a burn spot and tight fit to no avail.
It is likely the power amp chip has shorted. This puts the unregulated dc into the speaker and you will hear the hum. DO NOT operate this way as you can burn up the speaker. You will find that the LM3886 chip on the heatsink has failed. They are about $7.30 from Digikey. They come in two lead bent versions. Make sure to get the correct version and use heat sink grease wheen installing.
3helpful
Clip light is on even when no input and when bass is plugged in input low volume and distortion at speaker output
One half of the power amp has failed. You can damage the speaker... do NOT use this until repaired.
My bass amp Behringer bx 4500 dont have power when I turn on the switch. I check the fuse but it was fine. What could be the problem of the amp when it does not turn on?
First thing is to verify that the power cord is GOOD and that it is fully seated. Beyond that repair is NOT DIY. Take it to a repair shop.
1helpful
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
