UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
For
OBD code problems check the list of help links below. Click the link
below to go through its procedure.
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code P2195?
http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121?
http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330?
http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330?
http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300?
http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768?
http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions
System codes details?
http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html
Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO
BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error
Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car
Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes
list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
list?
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code
without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code
P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from
Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540
continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is
shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with
codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code
P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and
P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This
will help.
Thanks.
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
Diagnostic error code P0121,P0505,P1000,P2101,P2104,
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Diagnostic code P0010?http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html-------------Diagnostic Code P1396?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
OBDII scan is receiving NO BUS CODE?
How to Clear OBD error Codes?
Diagnosis and Testing Car Components?
Diagnostic Trouble Codes list?
Part 1.
Part 2.------
Code P0132?
P0031 code?
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
Getting diagnostic code P0016?
How to Read Codes from Check Engine Light?
Diagnostic Code P0540 continues to return and the MIL light is on?
Car misfires and error code P0306 and P0303 is shown?
Check engine light with codes P2195 and P2197?
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
OBD code P0301, P0430 and P0174?
OBD code P0500?http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
-----------This will help.Thanks.
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
Part 1.
Part 2.------
Code P0132?
P0031 code?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
For
OBD code P1330?
OBD code P01300?
OBD code P0768?
Code P0452?
DTC Code P0321?
Error Code P0471?
P0304 Error code?
BUS CODE?
Codes?
Components?
list?
Part 1.
list?
Part 2.------
Code P0132?
P0031 code?
P0016?
Check Engine Light?
shown?
P2110,P2135,P2106?
P0352 Obd code?
Error code p0402?
Obd Code P0763?
P0174?
OBD code P0500?
This
will help.
Thanks.
