My machine is working just fine but when I stop sewing, my juki takes an additional 3 stitches before it stops. The 3 extra stitches are done in the slowest speed. I don't know how to make it stop when I stop. When I use my thread cutter, it speeds up the stitching but nothing is cut, it just goes up and down several times in the "normal" speed for cutting the thread. It wasn't always like this. The last time I took my Juki in it had got seized up on some fabric or thread, but when I got it back it started to do the two things above. I would love to be able to solve these problems on my own instead of taking it back in.
SOURCE: juki 5555
You probably need to insert a new needle but here is a link that should help you Claven.These things happen to all of us at one time or another
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
SOURCE: we are hving problems with
hi there
1 - remove throat plat and mak sure the movment for thread cutter working or NO if working maybe need to change fixed knife or movable knife.
2 - if no movment mak sure plug for cutter solenoid is connect secur.
3 - make sure the output signal is coming to the cutter solenoid or no.
4 - maybe solenoid is dameged and need to change.
with my best regards
ashraf abozid
[email protected]
SOURCE: Juki DDL-8700--top & bobbin thread won't hold together for stitch
What bobbins do I use on a Juki DDL-8300
