What does unb at end of wasn after it says end??
Unbalanced - means it didnt spin properly due to clothes being unbalanced. Its supposed to stop the machine damaging itself - but its just a pain. Need to fill the machine with a full load to avoid this. Dont suppose your machine's a Haier??
Posted on Aug 27, 2009
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
End and unb showing on machine, cant turn machine off on the settings
first of all unplug the machine let it rest for 15 mins then plug it back in again and try the machine otherwise call the engineer for a quote eric
Jan 09, 2018 | Washing Machines
End and unb showing on machine, cant reset it
please rephrase your message its hard to understand what you mean or go to the manufactures website and download the user manual and look in the trouble shooting guide eric
(apacer 512mb unb pc2-4300 cl4)
go to cmus and set bios restore default
Aug 03, 2012 | Acer Computers & Internet
I have a bush wd 1000 txve with error code unb and wont spin. What does this mean?
'unb' is likely to stand for 'unbalanced' and spinning shows any problem with balance the most!
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Mar 22, 2011 | Washing Machines
Unb after rinse cycle. What causes this error code and how can I prevent it from happening
Unb - Sounds like 'Unbalanced' - if there are too many clothes in the washer or you have heavy clothes on one side and light clothes on the other it might be tripping the balance switch. Try to even up the wash with similar clothes or lighter loads.
Dec 02, 2009 | Haier Washing Machines
Feb 17, 2009 | Haier HWD1000
Spinning but clothes are still very wet ,
unb means unbalanced i had the same problem and i called comet where i got it from and they replaced the chip board and ever since then its been fine i hope this helps you
Jan 27, 2009 | Haier XQG50-QF80 Front Load Washer
Spinner not spining on quick wash
THE cloths is not dryed anough till it spind lavamat w 80 washing machine
Oct 19, 2008 | Washing Machines
My Haier HW-C1460TVE-U washing machine was installed this morning did the empty cycle first then did a load of towels worked perfectly did another wash Err code Unb came up. Got sprit level and checked...
Have been to one of these machines today. UNB will still show even if the machine is empty. I think the feedback amplifier on the main PCB is at fault. If I have any luck with it I'll post another message
Jun 29, 2008 | Washing Machines
Washing Machines Logo
300 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
