Nespresso Aeroccino Automatic Milk Frother Logo
Posted on Jan 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Machine won't work
The on/off button had a delayed response for a couple of days and now won't work at all...i have had the machine for 6 weeks and love it! is there any kind of 're-set' button...what do you advise? Anna
  • Anonymous Feb 13, 2009
    I love the Nespresso Milk Frother but you can count on it to die. I have gone through four of these machines in the past two years. At first I thought it might be because I got the bottom wet but now I believe it is somthing else. It has a stick free bottom and when that fails burned milk accumulates. At that point, the cycle becomes shorter and shorter. This machine has a rather short half-life. With good care you may lengthen it but eventually the Frother will die.
  • cafeconleche Feb 28, 2009
    i have same frother and it lasted over a little more than a year
    i call them and no more warranty
    theres got to be a better one out there
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1125
Points
I bought my nespresso aeroccino second hand; It seems to work fine but wondering where I can get a manual. Anyone know?
Ginko
Level 3:
  • Nespresso Master 19,396 Answers
  • Posted on Jan 03, 2009
Ginko
Nespresso Master
Level 3:
Answers
19396
Questions
25
Helped
8074831
Points
55462
This machine does not have that muck electronic, the button switch has probably a short, and must be replaced.
As said the machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
My son developed 2 skin lesions on his lower right leg a week ago,They are 25mm long red with uneven sides, very itchy the first couple of days. what can this be?
There is a large number of possible causes, some serious, some transient like plant allergy. Your only real choice is to go to a doctor, and I hope you have good access to health care. If unsatisfied with the response ask for a referral to a dermatologist.
Don't delay in case it is one of the nastier possibilities.
Good luck with this.
Start button won't work, but delay does
have you accidently turned on a safety feature stopping the machine from starting? or is the door latches closed fully, if opened slightly could be preventing the machine from starting. or maybe its just a faulty start button.
2answers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
4helpful
I have just bought the yardworks 2 zone water timer from Canadian Tire and there are no instructions anywhere. I have managed to get it to work for one minute and I have it set to do the same in one hour...
Delayed Watering
You can delay the first watering cycle of each watering zone by up to 12 hours by using the small button at the bottom middle of each zone area. Press the delay button 1 time for each hour you wish to delay the first start time. The "Low Battery" light will illuminate when you press the button. The maximum delay is 12 hours.
For example, if you are programming at 4:00 in the afternoon and you want your timer to water every 12 hours, but you want the first watering of the day to start at 6:00 a.m., press the Delay button two times. Without the delay, the first cycle would have occurred 12 hours after the timer is programmed (4:00 a.m.). The delay feature changes that to 6:00 a.m. The timer will then water every 12 hours after that.
Aug 02, 2011 • Garden
I have a Magic Chef dishwasher - only a couple of years old. About once every two weeks (I use it 5 times per week) it won't turn on. The only button that does anything is the delay wash button. If...
You have an intermittent contact somewhere that vibrations will every once in a while restore contact. I would clean and crimp every stinking electrical connection in the unit including the door switch. You do that, and I am sure the unit will be fine..
13helpful
2answers
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
2answers
Delayed and unressponsive keyboard
the keyboard may just need servicing so take the phone and have that done at a repair shop/
Top Nespresso Coffee Makers & Espresso Machines Experts
Kolbrun...
Jay Finke
Jay Finke
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
