Hi, I've recently inserted a generic (black) ink cartridge as my old (also generic) one went out of ink. I bought a colour cartridge and black cartridge at the same time from the same generic brand, but only my black one is being refused by my HP PSC 1510 all-in-one.
I've tried various approaches after searching on the net, for days on, but to no avail.
I would be extremely grateful if someone can help me out.
Thanks a lot in advance!
SOURCE: HP PSC 1510 PRINTER
first ckeck out the your cartages are ok and then when you start the printer them it print the alignment page then put it in the scanner and scan it your problem will be surually solved
SOURCE: HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
SOURCE: hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
SOURCE: cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Testimonial: "This site is excellent. Thanks for your help."
SOURCE: I cannot scan with my H-P 1510 PSC ubder Vista.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&lang=en&product=428800
from here download and install the driver ..update
I'm having the same problem with an HP psc2310 all in one. I was using the generic black ink cartridge for some time before this happened. Now, no matter how often I remove and replace it, it won't work.
I have the same problem, but mine is the 6110 all in one. It was working fine now it say's its the wrong cartridge. HELP
same problem, need help
Me too
