Question about AO Smith A O Smith Motors Centurion 1.5hp 115/230v Aluminum Keyed Motor
Need to know what wire goes to were..on a smith & jones modle 67841 compresser motor..p1 p2 t2 t3 t4 t5 t8..to what wire black white green
There is a green black and white wire..on my compresser..on the smith jnes compresser there is p1p2 t2 t3 t4 t5 t8..were do they go to witch wire to what
  • phil ledford Jun 19, 2013
    Does anyone know which is the proper capacitor for this motor model 67841 smith + jones 1.5 hp motor....
    New Friend:
Hey guys, this motor is reversible. I have it wired to turn clockwise(according to diagram),
green to ground;
L1 (black) to P1;
L2 (white) to T2-T4-T8;
P2-T3-T5 together .
When I plug it in, the motor turns counter clockwise and the on/off switch does not work. How do I fix?
Posted on Jan 07, 2015
SOURCE:
john224
  • 1378 Answers
SOURCE: Which wires goes to which post ? Just bought an
It does not matter. Just make sure it is set to the correct voltage your system supplies to it and that you put pne wire on each terminal as the diagram on the side of the motor will show you.
Posted on Jun 14, 2009
  • 10865 Answers
SOURCE: Which wire goes to which post ? Intermatic T104R
The two wires are interchangeable.
Posted on May 06, 2009
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
Wiring a smith and jones 1 hp electric motor for 220. The diagram is not very helpful. I have a red and black hot lead and a white neutral. Where do they all go? I want to make the motor go ccw.
Ok from what I read on the diagram take one lead to P1 cap of P2 T3 T8 and T2 are together and T4 and T5 are put to the second lead
If you want to change direction exchange T5 and T8
Feb 11, 2017 | Smith Pool & Spa
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
How do i rewire a broomwade 3 phase compressor 1970
Rewire for ?? High voltage motor wiring is L1-T1, L2-T2, L3-T3, T4-T7, T5-T8, T6-T9. Low voltage is L1-T1-T4, L2-T2-T5, L3-T3-T6. The motor protection overloads will need to be sized accordingly, to the motor's FLA ( full load amps) for the voltage used. The control needs to be looked at also, if there is a control transformer, the transformer needs to be wired or repaced for the new supply power voltage used.
Mar 12, 2015 | Air Tools & Compressors
Wiring diagram for 230v
Single phase motor for 230V, connect T4 and T5, to one line. T2, T3, T8 common connected. T1 to other line. Check Rotation, This should be for CCW rotation facing output shaft. Swap T5 and T8 for CW rotation.
Jan 17, 2011 | Ingersoll Rand TS4N5 Ir Electric...
I need to wire my DJ-20 Jointer back to 230 and I don't have schematic Suggestions?
Assuming you have a standard dual-voltage single-phase motor, your wire colors should be:
T1 - Blue
T2 - White
T3 - Orange
T4 - Yellow
T5 - Black
T8 - Red
For 220V wiring, you want:
Line 1 (to Black wire from switch):
Blue
Black
Line 2 (to White wire from switch):
Yellow
Tied together with a wire tie:
Red
Orange
White
This should make it so the shaft spins counter-clockwise. If you need it to spin the other direction, switch the red and black wire from the motor.
Jun 23, 2010 | Delta X5 Dj20 8" Precision Jointer
I NEED TO REWIRE A DOERR LR22132 ELECTRIC
The green should be connected to the chassis, it is ground.
There should be a wiring diagram on it to tell you how to do this, but if not:
There may be T-leads on the motor labeled
P1, P2, T3,T4,T5,T8
P1-L1(black wire)
P2-cap/tape don't use.
T2,T3, and T5 wire nut together
T4,T-8 wire nut together with L2(white)
The power leads will be coming from your switch box on the compressor body itself. Don't wire the 220v directly to the motor, you replace the leads where the first motor was connected on the cutoff switch. There will be only 2 leading from the switch to the motor.
Mar 24, 2010 | Plumbing
I have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great, paul
i have a doerr electric motor, lr22132 single phase 220v, 3/4 HP with wires t2, t3, t4, t5, t6, t7, t8 and earth, how do i hook up, any help would be great,
Nov 20, 2009 | Kitchen Appliances - Others
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
AO Smith A O Smith Motors Centurion 1.5hp 115/230v Aluminum Keyed Motor Logo
4,814 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
US Parts Center
US Parts Center
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
