Taylor Dgtl Body Fat Scale Logo
Anonymous Posted on Jan 03, 2009
The sound gets on my nerves
I don't know if all scales do this but the Taylor 5570 beeps or makes a sound everytime you want to see your BMI. Is there any way to get rid of that noise?
Anonymous
Level 2:
  • Expert 74 Answers
  • Posted on Jan 07, 2009
Anonymous
Expert
Level 2:
Answers
74
Questions
Helped
136232
Points
168
This link provides a troubleshooting/FAQ directly from the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
I don't have a manual. My scales have been very variable, like this morning showing that I had gained nearly 5 lbs in one day. I've been sick and am not eating much, so I know that can't be...
I don't have a manual. The readout is in kilos rather than pounds some of the time. How can I get it to read in pounds all the time? Also I replaced the batteries. Are they supose to be both with + up? I have a replacement heart valve so I don't want to know body fat. How do I make sure it is off?
2helpful
Need user manual for TAYLOR 55684102 scales.
Here is my link, uploaded it to my photobucket album.
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
I'm trying to find the operating manual for the Taylor Body Fat Scale (with Fitness Minder BMI Technology)
I just pulled my manual, as I recently started a slow carb diet and needed all my measurements. It was fun trying to find it. After finding nothing online (before my search), decided to post mine for everyone out there. It can be found under my photobucket album. Here is the link:
Amy
Taylor 5568 scale will not display lbs - just kgs when I tap and step on it. It's the Biggest Loser body comp model. It was working fine,displaying lbs, then one morning it ws just kgs and I can't get it...
Don't know if this will help, but here is the manual.....see my photobucket link:
Amy
2answers
It is not showing me my BMI or BMR! How do you get that to show?
BMI + BMR do not show up when the scale is set in child mode. It's possible you have it set on child, instead of male/female. I have the manual uploaded on photobucket if you needed it.
Amy
2answers
What is mean by body mass index?(bmi)
Is a measurement to determine a persons weight over height the formula is weight(KG) / height(METRES), a normal healthy person should have a bmi of 18.5 to 25 anything above this means the person is fat to obese
4helpful
How do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
1helpful
Instruction manual soehnle scale I need to rest the scale so it shows the bmi, hydration and weight.
I have looked and maybe you have the model number wrong the scale you are talking about 63700 Calando Quattrotronic scale is a simple digital scale and does not provide bmi, and hydration.
here is a link to the manual, http://www.leifheitusa.com/manual/63700.pdfit is in several languages including english as the company is european and sells to many countries. If you look english is there it is a very simple manual as the scale is only desinged to weight in either lbs or kgs nothing more. Sorry. If you would like a bmi chart you can get that here http://www.healthdiscovery.net/links/calculators/body_massindex_chart.htm and figure out your bmi based on height and weight in the chart.
4helpful
2answers
Lost manual, need instruction on how to reset Taylor 5700 BMI
personalcare.owneriq.net/manuals/mfg/taylor/5571.html
go to that address and you can download the manual.
Top Taylor Health & Beauty Experts
ZJ Limited
ZJ Limited
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
