I have replaced the thermostat to!
Sounds like this may be a faulty fan motor, the low speed in these fan assemblys go bad, but the hi speed works when the a/c is turned on. I would check for the cooling fan relay first... you can usually switch this relay with another relay of the same and see if that makes the fan kick on, if it doesn't then i would go with replacing the electric cooling fan motor. Hope this helps
SOURCE: radiator fan will not kick on
Check you replaced the correct fan control sensor switch (not the temperature gauge sender),
Check fan fuse,
Check fan control relay operation,
Check fan will run if power applied directly to it.
SOURCE: my 98 ply gr voy
The problem is most likely be related to the wiring. I would suggest to have the wiring harness inspected. A visual inspect inspection is needed. What you are looking out for are loose wires or wires with bad insulation, exposed copper or terminals which are bad and may need cleaning.
Heat affects electrical devices especially the conductor. After running a grounded wire may have difficulty conducting electricity due to the increase in temperature. Vibration also affects this especially if it is a loose wire issue and problem may appear intermittent depending on the nature of vibration.
