Whirlpool Duet WFW9151YW 27" Front-Load Washer with 3.5 cu. ft. Capacity, 12 Wash Cycles, Cold Wash Cycle, EcoBoost/TumbleFresh Options and 3 Temperature Settings Logo
Ed Jepson Posted on Oct 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We HAD a Whirlpool Washer model #WFW9750WW01. It died. We HAD a Whirlpool Drier model #WED9750WWO stacked on top of it. We may replace the washer with a Whirlpool washer model #WFW9151YW. Will they stack? Will we need a different stacking kit??? Our present stacking kit is #8541503.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 249 Answers
  • Posted on Jan 24, 2013
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
249
Questions
Helped
45760
Points
519
What do you need or to fix or what is it then
1helpful
Calibrating whirl pool washer after repair
Linda. I know nothing about this washer, but I did get this info from the attached link, you may still have to call a tech.
Put into diagnostics (left, right, right, right, left, right) @ done you see errors, @ spin you run calibration(this will clear codes and reset board). good luck
http://forum.appliancepartspros.com/washer-repair/537059-whirlpool-cabrio-washer-not-completing-spin-cycle.html
2helpful
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Washer is leaking by the hoses
If your washer is leaking from the connection where the hose and the hose end join, replace the hose. If it's leaking from where the hose attaches to the washer, check and see if there is a rubber washer inside the hose end, there should be, try replaceing the rubber washer inside the hose end,
How do I fix my whirlpool cabrio washer is showing code sD
Ideally, you just run the washer without any detergent and it'll rinse out all the soap. Try that first. My Cabrio started doing that all the time, then stopped spinning out all the water. It had a host of problems and I opted to replace the washer. Hopefully the water rinse will fix the problem for you.
How much is a lid switch for a whirpool washer
Depending on model there not much, I usually hot wire mine..just take the switch off and connect the wires together with a wire nut...
I have a cabrio top fill Washer model #WTW5500Xw1 that will not fill with water
Both hot and cold water or just one type. Check the hose in line filters, they could be clogged.
How do I replace lid assembly for Whirlpool WTW8800YC 4.6 Cu. Ft. Cabrio Platinum Top Load Washer
Hi Sarah, there are two screws on each side of the lid holding the shaft for the hinges. Open the lid to access them, You will need an Allen wrench to take them off, after that, just lift the lid up to take it out. Hope this help. Thanks.
Top Whirlpool Water Heaters Experts
Paul Carew
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
