SOURCE: new world DW60-flashing lights
This dishwasher uses the program lights a s a fault code. Usually it is due to food jamming the impeller. If you are competent you can get at it from underneath. Mine was under warranty when this happened and the engineer was heard to say, 'this is a dishwasher not a waste disposal'. The engineer cleared it with a wire coat hanger down the drian hole inside the machine. Not happened since we really scape off plates.
SOURCE: new world wd60
i made sure drain hose was not blocked found gunk at bottum , but to reset alarm e4 , had to drain dishwasher put it on its side - must have remove an airlock. checked turn on and e4 had gone , all ok now suggest rinse all dishes before washing
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
