Question about Troy-Bilt Pony Garden Tiller
Econo-horse tillerser.#e023842 need new oil seals on tine shaft
  • 430 Answers
You can order them from your local MTD dealer.
Posted on Nov 05, 2012
5 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Posted on Feb 14, 2009
landsend
  • 1066 Answers
SOURCE: leaks oil around the tines.
 an new oil seal needs to be put onto the output shaft of the transmission.  remove the plug wire if you attempt to pry out the old seal and tap in the new seal.  Be careful not to damage the case and grease the seal and shaft when you replace the oil seal
Posted on Mar 29, 2009
  • 26 Answers
SOURCE: troy-bilt horse engiine runs good , tines work,
The wheel shaft on a Horse tiller is one piece so if the shaft turns on one side it will turn on the other. make sure the pin that holds the wheel on is not missing that would let it spin on the shaft.
That's the only thing I can think of that would cause that problem. Hope that helps.
Frank
Posted on Oct 07, 2010
  • 26 Answers
SOURCE: When the clutch is disengaged the tines still turn.
If you email me at fbarnes@mfa-inc.com I have a couple of Econo-Horse manuals that I downloaded that I can email to you. They don't really have a clutch just belts and pulleys so its probably just needing a new belt or a belt tension adjustment. I have a Econo-Horse tiller and it is a nice machine I think mine is about the same age as yours.
Good Luck,
Frank
Posted on Oct 08, 2010
Leaking tine shaft
your seal on the shaft defective,
www.ask.com/mfg.name/make/model/service/parts/leaking/tine/shaft/
Oct 02, 2015 | Troy-Bilt Troybilt Horse 6, 7 And 8 Hp...
The rear tine seals are leaking ive taken the bolts out but the tines will not come off what can i do
You could try putting the tiller to use, preferably where it will have to work hard to till the ground it unsuccessful you may need a torch and some good old fashion luck to loosen tines from shaft. Now consider this; if the bearings are worn so that the shaft is loose new seals will not hold up and you will risk doing further damage to the worm gear located on rear shaft and possibly other damage to your transmission from contaminated oil.
Mar 04, 2011 | Troy-Bilt Pony Garden Tiller
The oil seal where the tiller attachment fastens to the tiller is leaking how do i remove the seal
IF THIS IS A WALK BEHIND TILLER OR FRONT TINE TILLER. THERE SHOULD BE PINS OR BOLTS HOLDING THE TINES ON THE DRIVE SHAFT REMOVE THESE AND PULL THE TINES OFF THE TILLER. THEY MAY GIVE YOU A HARD TIME GETTING THEM OFF SO DON'T GIVE UP. ONCE YOU GET THE TINES OFF YOU SHOULD SEE THE SEALS YOU CAN POP THE OLD ONES OUT WITH A SCREW DRIVER CLEAN OUT THE SOCKETS WHERE THE NEW SEALS WILL GO REPLACE THE NEW SEALS GENTLY WITH A SMALL HAMMER TAPPING THEM IN EVENLY AND TRY NOT TO BEND THE SEAL
Feb 05, 2011 | Garden
I have a 5 hp troybilt pony tiller. The axle seals need replacing can you describe the best way to replace them. This tiller was built in Feb. of 1990.
http://www.mtdparts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10101&catalogId=19502&langId=-1
Go to this website and type in PONY for your model number and find your operator manual by your serial number. The operator manual should have detailed instructions on how to replace your seals.
On the Horse model you remove the wheels and then carefully use a couple of screw drivers to pry out the old seals being careful not to scratch the wheel shaft sealing area. Then polish the wheel shaft with fine emery cloth to remove any sharp edges. Then grease the wheel shafts and carefully slide the new wheel seals on and use a piece of plastic PVC pipe cut square that will slide over the shaft and gently drive the seal to the depth the old seals were installed at. You dont even have to drain the gear oil. Getting the wheels off the wheel shaft is sometimes a problem if they are rusted on. if you can get the wheels off its not to hard to change the seals.
Frank
Sep 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Good Luck,
Frank
Jul 08, 2010 | Troy-Bilt Pony Garden Tiller
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Leaks oil around the tines.
Mar 29, 2009 | Troy-Bilt Garden
How to remove rear tines to replace seals ?
The tines sometimes get frozen to the shaft. You might try penatrating oil and use a heat gun or hair dryer to heat to loosen.
Also tap wiht a hammer around shaft.
Mar 19, 2009 | Troy-Bilt Garden
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
61 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Wayne McNeil
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
