When I TRY to delete songs from my coby MP-705 player, the songs I want to delete won't show on my computer screen ((Windows Media Player))... What do I need to do?!?! HELP!!
I had the same problem - VERY frustrating. Just found the answer, and am very happy to share it!
1. In setting/USB mode, select MSC mode.
2. Plug in Coby to USB
3. Open My Computer. Look for the Coby as a REMOVABLE DISK, not the Coby.
Files will be there for Viewing and Deleting! (On XP, at least).
4. Make a backup of MTP.BIN and WMPInfo.xml, which I think is the operating sytem?
I got the clue from here:
http://www.fixya.com/support/t357600-problem_coby_mpc7095_2_gb_mp3_player
Paupaul
Well, turn on you mp3 player, go on setting/USB mode and select MSC mode.
Then plug it on your computer and check in MICIN.DIR folder. You must find them.
It wasn't exactly what I saw, but once I looked, it was all there. Perfect!
My daughter and I had the same problem. We found that we had some songs buried in other folders so we went through every file and just decided to delete everything and start over. It worked for us.
SOURCE: My Coby MP-705 Won't Let Me Delete Songs
Just format your player and it should get rid of everything, including the preinstalled junk. Right click 'internal storage' and select format.
Make sure your player is not active. Unplug it from your computer and turn it off. Now plug into your computer. Go to the start menu on your computer and select "run". Type in the port your unit is plugged into or use the dropdown and select. This should display your 705 contents. Highlight the file you want to delete, then right click and select delete. Hope this helps.
My MP4 won t delete the songs please help me
MY COBY MP-705 WONT LET ME DELETE THE SONGS IN IT. I TRY 2 DELETE THEM ON WINDOWS MEDIA PLAYER BUT IT SAYS WINDOWS MEDIA PLAYER CANNOT DELETE A FILE FROM THIS DEVICE
i have the same exact problems and i really need to delete stuff cause there is some nasty stuff (in music) that is on there. PLEASE HELP ME!!
